Mk2 Cooper
459 replies to this topic
#331 Daz1968
Daz1968
  • 2,058 posts
Posted 15 July 2017 - 07:28 PM
Thanks, never thought about that, if I have any issue then as raptor is supposed to dry rock hard and it's solid colour I could flat it down, I never had issue on my mk1 but that was normal stonechip so being soft squashed up when subframe tightened.
Hopefully though there is enough flex in the rubber mountings.
I haven't painted raptor inside front panel near mounts to ensure front subframe goes in easily.
Still have a way to go but feels better now one area is complete
#332 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 16 July 2017 - 07:13 PM
I would be interested to see how well the Raptor holds up.
I think it would be something i would consider using at work. I didn't realise it was tintable.
#333 Daz1968
Daz1968
  • 2,058 posts
Posted 16 July 2017 - 07:59 PM
I don't think my car will give it a good test, but plenty on 4x4 forums are using it and it's proper use is a truck liner so should be very hard wearing. I bought mine pre tinted but they only add 10% base tinters, main reason I used it was to replace one complete operation as on my mk1 I had to stone chip and then paint and I am hoping as it's solid colour any stonechips wont show. It went on very well, I am happy with texture as it's pretty even although rougher than I initially was aiming for. Think to get it smoother it really needs thinning slightly and can even be put through a gravity spray gun.
It came recommended to me from people who have moved from gravytex.
#334 Daz1968
Daz1968
  • 2,058 posts
Posted 18 September 2017 - 05:35 PM
Thought I should post an update, I managed to get all flatting finalised for topcoat and painted inside of the car, then removed off the spit
37144629431_396d832ac4_c.jpgIMG_2140 by darren carr, on Flickr
I then spent a few hours tidying up, vacuuming and getting ready to build my booth for topcoat, although I also trial fitted the bonnet again to check the fit, am happy with it so can now get some colour on it,
37114629112_2320035dab_c.jpgIMG_2138 by darren carr, on Flickr
Been a long road to get this far so hopefully won't ruin it now.
#335 Daz1968
Daz1968
  • 2,058 posts
Posted 24 September 2017 - 06:59 PM
Decided to spend my weekend getting ready for paint,
I have built a framework which will be covered with body shop plastic sheet, I also have 2 filters, one for intake and one for exhaust,
I have put2 coats of pva on the floor and on the one exposed wall to help prevent dust so will start sheeting the frame in the week, hopefully going this way I will avoid the mistakes I made on my mk1 and get far less dust in the paint and hopefully less rework and flatting,
I have also bought some more lighting to help so hopefully be ready to paint very soon.
37244228436_294a499f6f_c.jpgIMG_2152 by darren carr, on Flickr
#336 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 24 September 2017 - 07:54 PM
Don't know if if you have tried it, but if you ground the body before you start
panel wiping and tak-raging, and keep it grounded during paint operations it
helps to stop dust being attracted to the paint finish.
I have painted a fair few cars over the years (50 odd ) in all sorts of conditions
and places and found this helps when not in a proper Booth/oven.
Best of luck,
#337 Daz1968
Daz1968
  • 2,058 posts
Posted 30 September 2017 - 05:06 PM
I finished my booth off in the week
23560499568_2e9a100999_c.jpgIMG_2170 by darren carr, on Flickr
23560500148_329aeb623b_c.jpgIMG_2169 by darren carr, on Flickr
Then I masked off the car, painted inside boot, although difficult to get a good picture
37365266466_ebe131a099_c.jpgIMG_2171 by darren carr, on Flickr
Then painted under bonnet area
36703204294_a82ac44698_c.jpgIMG_2173 by darren carr, on Flickr
Also gave inside of bootlid a couple of coats
37381783082_dda777a6a2_c.jpgIMG_2172 by darren carr, on Flickr
Also painted a few brackets and bonnet hinges,
still got a few bits of dust but nothing like when in an open garage, well pleased with the effort it took to construct.
Need to get some time to finish it off now
#338 g111mds
g111mds
  • 432 posts
Posted 02 October 2017 - 08:41 PM
After pointing me in the direction of your thread to look at the windscreen aperture replacement, I've now had the chance to read through all the pages. Absolutely fantastic work on this.
#339 Daz1968
Daz1968
  • 2,058 posts
Posted 02 October 2017 - 09:40 PM
Thanks, been a long time to get this far but starting to see it coming together now
I have painted inside the doors as well now, got two small runs but they should flat out, I need to practice a little more as it's a fine line between full wet coat and a run.
36790996943_f02f0c8cdd_c.jpgIMG_2177 by darren carr, on Flickr
37460840121_e7acc9e35e_c.jpgIMG_2176 by darren carr, on Flickr
Also painted a few more bits
36790996223_94aa78d373_c.jpgIMG_2181 by darren carr, on Flickr
Will paint outside of doors, bonnet and bootlid before I start on outside of car, very pleased with the lack of dust though, was well worth the effort to set up the area. I have won a large extractor on eBay so should have that before end of week
Edited by Daz1968, 02 October 2017 - 09:41 PM.
#340 slidehammer
slidehammer
  • 1,180 posts
  • Local Club: LSMOC
Posted 04 October 2017 - 08:10 PM
looking good
#341 Daz1968
Daz1968
  • 2,058 posts
Posted 21 October 2017 - 02:35 PM
not had much chance to do anything on the car recently, but finally got an update.
I did a trial run on the bonnet and boot after finalising my booth and extraction, got a few bits of dust but far better than previous attempts.
I also invested in the farecla ops flexible cups and even though it was a little expensive due to quantities you have to buy, it was worth it for the ease of cleaning up and no chance of leaks when painting hopefully. Also it took very little thinners to clean the gun,
37121251584_10c5350b31_c.jpgIMG_2221 by darren carr, on Flickr
37121248554_960d13b853_c.jpgIMG_2223 by darren carr, on Flickr
37121250274_67ab4a523a_c.jpgIMG_2222 by darren carr, on Flickr
Will leave any flatting and polishing for a while as it's a skill I haven't quite mastered yet. Think I need to paint and old panel and practice on it.
Hopefully paint roof in snowberry white next week. Which is one reason I bought the cups as I have spilt paint on the roof before and had to flat and repaint.
#342 MrBounce
MrBounce
  • 2,629 posts
Posted 21 October 2017 - 02:38 PM
Fantastic work Darren  :thumbsup:
#343 gadget555
gadget555
  • 152 posts
Posted 21 October 2017 - 07:12 PM
Wow!
#344 73MkIII
73MkIII
  • 158 posts
Posted 21 October 2017 - 08:55 PM
its different that colour isn't it? I like it. Not sure I have seen a mini that colour before.
#345 73MkIII
73MkIII
  • 158 posts
Posted 21 October 2017 - 08:56 PM
what is the colour called? or did you have it mixed?
Edited by 73MkIII, 21 October 2017 - 08:58 PM.
