Decided to fit the correct indicator plinths to front panel,
Did first side by chopping out a square section,
Although it worked ok I had more distortion than I would like, needed a lot of reshaping and although not finished the shape is there now just needs a little smoothing and filling
Did second side by cutting out a circular section using a grinding disc as template,
Came out much better so a lesson learned for future
The indicator looks much better on correct diameter plinth
Than after clamping and screwing the front end together for alignment I removed the wings and front panel and spot welded together as access much easier.
Front end now refitted and clamped in position, needs a few adjustments but almost ready for welding
The wings and scuttle are heritage but front panel is pattern part modified to correct spec by m machine.
Edited by Daz1968, 14 August 2016 - 04:22 PM.
