Mk2 Cooper
459 replies to this topic
#241 Daz1968
Daz1968
  • 2,058 posts
Posted 05 June 2016 - 01:58 PM
I managed to finish off the upper repair patch today, not got time to weld it in position but pleased with it and once tacked in I can dress it into shape a little more, was a bit of a challenge making this but am getting better with practice.
Need to get some 12mm copper bar to make some modified electrodes for my spotwelder so can get into gutter area especially for when I replace the windscreen surround and fit new drip rails.
Going to enjoy the weather for a bit now can't keep working
#242 James_eaton_thewholething
  • 1,063 posts
Posted 06 June 2016 - 09:16 AM
Coming together now mate. I love the roof repairs so far
#243 Daz1968
Daz1968
  • 2,058 posts
Posted 19 June 2016 - 05:36 PM
Been on holiday and had a car show today so didn't get much time this weekend, but did manage to get the repair piece welded in, needs a little more grinding and hammering into shape but pleased with the repair so far, just got to remove the windscreen surround now and try to fit that, I also bought some copper bar off eBay so I can make some electrodes to weld the roof in the gutter,
#244 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 20 June 2016 - 05:37 AM
Looks like a nice repair there :)
#245 Daz1968
Daz1968
  • 2,058 posts
Posted 25 June 2016 - 04:47 PM
Thanks,
Managed a little more today as I have this panel as my next challenge, not looking forward to it but got to do it now
I did a little welding including plug welding closer panels then cut out panels on drivers side and slit panel just under gutter all across.
Then I cleaned derusted and painted inside pillar.
Need to repeat on passenger side then get some bracing in.
The part I am dreading is sanding the roof flange ready for spot welding as it's roll spot welded on, I will be spot welding as close together as I can
#246 minimissions
minimissions
  • 3,427 posts
Posted 27 June 2016 - 05:42 AM
Look forward to seeing that fitted as we have the same repair to do on a pickup at somepoint.
#247 Daz1968
Daz1968
  • 2,058 posts
Posted 09 July 2016 - 05:44 PM
Well managed a little more this afternoon,
Finished removing remains of old panel and had to do a little repair on front lip of passenger side roof
Just welded a new flange in position.
Then seam sealed and painted inside box sections
Tried to fit the surround but as it's usually fitted without the roof in position I had to remove the inner a post pieces and also the corner pieces of the inner rail are different on heritage panel so have had to remove those as well,
Just did a trial fit as it needs a bit of adjustment to get right but ran out of time today
The gutter isn't too bad on new panel but I have yet to sort out the open sections for drainage as later panel doesn't have them. Shouldn't be too difficult to sort it though as have sections from original gutter to help
#248 James_eaton_thewholething
  • 1,063 posts
Posted 09 July 2016 - 11:38 PM
Part of me wishes I had replaced that whole panel so wouldn't of had to build up filler of the scuttle joints. Looking good though mate
#249 Daz1968
Daz1968
  • 2,058 posts
Posted 10 July 2016 - 10:38 PM
Thanks for comment, I must admit I wasn't looking forward to changing this panel but once I had cut out the old one and decided best method to fit the new one I am now glad I went down this route as I have managed to fully derust inside a post now as only original part remaining is the upper section of the side panel. The roof corners have been much easier to sort with the panel removed, and when you think about it the panel was only about £60 more than the lower repair panel and I needed one of the inner panels that was fitted to it anyway, awkward bit was repairing flange on roof but I welded it from inside on corner so it's strong and I have some copper bar to make some smaller dia electrodes for my spot welder so I can get inside the gutter. I am still to decide easiest way to get the gutter drain points replicated but worst case is welding in the section from original gutter.
#250 Daz1968
Daz1968
  • 2,058 posts
Posted 16 July 2016 - 03:56 PM
Managed to get surround welded in position today,
Bonnet fit looks ok
Also inner upper a post panels welded in
Need to fit the upper corners of roof rail from my old one,
Then sort out the gutters
#251 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 16 July 2016 - 05:44 PM
Nice one  :highfive:
#252 MrBounce
MrBounce
  • 2,629 posts
Posted 16 July 2016 - 06:34 PM
I love your work Daz - such skill!  :thumbsup:
#253 blueovalcraig
blueovalcraig
  • 193 posts
Posted 16 July 2016 - 07:41 PM
Great work
#254 Daz1968
Daz1968
  • 2,058 posts
Posted 16 July 2016 - 09:01 PM
Thanks for kind comments,
I meant to add the picture of the spot weld electrodes I made to allow me to weld inside gutter from some 12mm copper bar I bought off eBay, they worked fine and may come in useful elsewhere
Edited by Daz1968, 17 July 2016 - 03:05 PM.
#255 minimissions
minimissions
  • 3,427 posts
Posted 18 July 2016 - 05:57 AM
Looks great nice big panel in there, really coming together now :)
