Mk2 Cooper
459 replies to this topic
#226 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 26 April 2016 - 05:27 AM
Looking great Daz, wont be long and that front end will be on and it will look like a mini again :)
#227 Daz1968
Daz1968
  • 2,058 posts
Posted 01 May 2016 - 04:50 PM
Thanks, been on holiday last week so decided to do a few bits today mainly small bits that need doing rather than starting anything major,
Ground down the bulkhead repair, should be ok now with a skim of filler although it won't be seen
Did a small repair to upper door frame
Before
After
Then fitted new door bottom from machine, had to drill holes in bottom but it fitter rather well
Then trial fitted frame to make sure all still ok
Gap at top is a little big I think, but will sort that after skin fitted and bolted in position with door seal in place.
Also found a small hole on rear pillar so welded a patch in that
Also welded a patch in roof where aerial was
My grinding flush isn't perfect no matter how I tackle it but nothing a light skim of filler won't cover
I Also spent an hour stripping paint off passenger side, well how much of it is left, have been using hot air paint stripper and works fine and not a messy as stripper,
Need to find a way to derust inside channel at top of door, it's only surface rust but quite difficult to get access.
Edited by Daz1968, 01 May 2016 - 04:52 PM.
#228 James_eaton_thewholething
  • 1,063 posts
Posted 01 May 2016 - 06:51 PM
looking good daz mate
Edited by James_eaton_thewholething, 01 May 2016 - 06:52 PM.
#229 minimissions
minimissions
  • 3,427 posts
Posted 02 May 2016 - 06:51 AM
Nice work this is really coming together now I like the look of those doors they are lining up nicely.
#230 Daz1968
Daz1968
  • 2,058 posts
Posted 02 May 2016 - 11:15 AM
Thanks, I think by keeping the doors on the car as long as possible and using them whilst lining up the other panels helped a lot. The full a panels also made it easier
Also trial fitted the doorskin today as weather prevented me doing other things I had planned, it's a magnum panel so needed a few alterations to fit the frame, basically had to flatten the edges near top and fold to get a nice gap. Also hole for handle needed altering slightly and hinge holes need moving a little. Just need to derust and paint the frame now before fitting properly. Probably won't get much done next week as hopefully going to himley show.
Edited by Daz1968, 02 May 2016 - 04:22 PM.
#231 Daz1968
Daz1968
  • 2,058 posts
Posted 14 May 2016 - 07:56 PM
Doesn't look much different on this picture but I have completed repairs to door frame, finished cleaning up the frame and painted inside with zinc primer, I then fitted the skin as best as I could. I am aiming for a 5mm gap all around so still need to build up and grind the edges in a few places but pretty pleased with it at moment. I also had to weld up and re drill upper hinge holes in skin and have yet to do a few alterations to get handle fitting correctly, both of which I had to do on my mk1. It is a magnum skin though but for the few things that need doing are well worth the saving, will leave as is for now and start work on the other side next time I get chance.
#232 Petrol
Petrol
  • 967 posts
Posted 14 May 2016 - 09:36 PM
Proper job this... It's attention to detail that makes all the difference - Respect :thumbsup:
#233 Daz1968
Daz1968
  • 2,058 posts
Posted 21 May 2016 - 05:39 PM
Thanks for kind comments
Managed to do a little more today,
Spot and plug welded inner a panel in position
Spotwelded outer a panel to inner wing
Then spent a little time removing the internal bracing, a big step really
Then I removed skin from drivers door, frame not too bad but will replace bottom as have panel already,
Then trial fitted frame in shell, fit looks ok so will repair frame and get skin fitted next
Once this door is completed will tackle roof corner repairs and fit new drip rails before tackling the front end
#234 James_eaton_thewholething
  • 1,063 posts
Posted 22 May 2016 - 05:30 AM
Good work on the other door, at least this one should be easier lol
#235 ToM 2012
ToM 2012
  • 4,066 posts
Posted 27 May 2016 - 06:43 AM
Looking excellent daz cheers Tom
#236 Daz1968
Daz1968
  • 2,058 posts
Posted 27 May 2016 - 04:01 PM
Thanks,
Did you get yours started, if not after this weekend I should have a bit of spare time, have been a little tied up with cars at moment. Have been working on my daily for mot so full service etc, then I have been working on another car ready for a car show at ragley hall on Sunday. I also have mk1 mini mot next month but not too worried about that one as only did 300 miles since last mot. Then have had to fit in some time on this restoration. Good job I have an understanding wife, the kitchen decorating has been postponed again.
Darren
Edited by Daz1968, 27 May 2016 - 04:02 PM.
#237 Daz1968
Daz1968
  • 2,058 posts
Posted 30 May 2016 - 06:32 PM
Not much done today, but I did decide best way to complete the door frame repairs, I am going to fabricate the section in situ then when I remove window surround I can get full access to back to get some paint in there.
Only managed to fit one piece in position but think it's probably easiest way to tackle this area.
#238 minimissions
minimissions
  • 3,427 posts
Posted 31 May 2016 - 05:39 AM
This has coming along nicely bet its nice to look back at it and see all that solid steel it looks great...
#239 Daz1968
Daz1968
  • 2,058 posts
Posted 31 May 2016 - 06:20 AM
Thanks, yes I agree looking at all the repairs makes it look far better. Posting updates on here also gives encouragement to continue.
Darren
#240 Daz1968
Daz1968
  • 2,058 posts
Posted 04 June 2016 - 05:32 PM
Managed to get a little more done,
Cut out rot on roof corner
Than fabricated a piece to put in and welded in position, surprised it had no distortion, will only need a light skim of filler later
I then began fabricating a piece for upper door frame but had to get some other jobs done so not finished yet,
Hard bit I think will be modifying the new windscreen surround to mk2 spec with the drain cutout
