Mk2 Cooper
459 replies to this topic
#181 ToM 2012
ToM 2012
  • 4,066 posts
Posted 28 February 2016 - 09:13 PM
Looking great daz very quick work next time I look you will be getting it ready for paint lol keep up the good work 👍
#182 Daz1968
Daz1968
  • 2,058 posts
Posted 28 February 2016 - 09:38 PM
Thanks, I have found that now the floor is in its coming along much easier, I haven't forgot about you will be in touch soon
#183 James_eaton_thewholething
  • 1,063 posts
Posted 28 February 2016 - 09:48 PM
I found that once the floor was done everything was easier and pretty quick
#184 Daz1968
Daz1968
  • 2,058 posts
Posted 03 March 2016 - 07:51 PM
Not really an update but. Have purchased a replica hrg rocker cover for when it's finished and am very pleased with the quality and a hell of a lot cheaper than a rough original one, also got my inner wings ready for when I continue with the front just these need modifying to early spec.
#185 Vinay-RS
Vinay-RS
  • 2,097 posts
Posted 04 March 2016 - 06:08 AM
That rocker cover is so pretty.
#186 midridge2
midridge2
  • 1,794 posts
Posted 04 March 2016 - 04:12 PM
Could you measure the rear quarter window opening top to bottom for me please.
#187 Daz1968
Daz1968
  • 2,058 posts
Posted 04 March 2016 - 05:27 PM
I can do tomorrow but pretty sure it is tapered
#188 Daz1968
Daz1968
  • 2,058 posts
Posted 05 March 2016 - 03:12 PM
As I thought is tapered if I measuere at front end before bend is approx 14 1/4 inches and 13 1/2 in similar position towards rear
#189 Daz1968
Daz1968
  • 2,058 posts
Posted 05 March 2016 - 07:24 PM
Managed to get a little more done,
Welded in the a panel after checking alignment, still got to finish the upper one, but is held ok for now
I am pretty please with door alignment just the upper frame needs a little tweaking to get right but will do that when I can fit doors properly
The hinges just dropped straight in the holes so impressed with panel shape
Then I removed the old inner wing but it took a lot longer than I thought it would, the reinforcing plates are well and truly shot so will get a template done before I remove the remnants from the crossmember end, but other than that not much else requires repair.
The inner a post stiffener I have a new one but will be fitting last so I can get spotweld arms in to weld outer a panel to the inner wing.
Then I just wanted to trial fit the new inner wing to check alignment with floor and toeboard and can report its perfect so at least I repaired that area correctly
So next job is to modify it to early spec and repair and rust proof any areas before fitting it for the final time.
Am starting to enjoy it coming together now
#190 James_eaton_thewholething
  • 1,063 posts
Posted 05 March 2016 - 08:05 PM
Daz are you trying to tell me you haven't finished this yet. Sigh
I joke looking good mate. It's definitely so much nicer and easier to replace the whole inner wing and at least you know it's all solid and won't have to be repaired again soon
#191 Daz1968
Daz1968
  • 2,058 posts
Posted 06 March 2016 - 06:38 PM
Done a little more today
Made a replacement crossmember end reinforcing plate
Then I removed incorrect one from inner wing and cut out the later windscreen wiper indent and made a patch to correct shape
All welded but still need to grind back
Then I spent a little time removing any rust from end of cross member and cleaning everything up, I now need new brackets for the ends so will order Monday, not got any pics of this stage though.
#192 Van13
Van13
  • 314 posts
  • Local Club: Unknown
Posted 06 March 2016 - 07:44 PM
Love your build thread no expense spared and excellent skills keep it coming
#193 slidehammer
slidehammer
  • 1,180 posts
  • Local Club: LSMOC
Posted 06 March 2016 - 11:03 PM
Looking good as always
#194 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 07 March 2016 - 02:24 PM
This is awesome as ever glad I have managed to see those a panels go on :) is the inner a panel attached to that new flitch and inner wing panel?
#195 Daz1968
Daz1968
  • 2,058 posts
Posted 07 March 2016 - 03:46 PM
Thanks, no the inner a panel is not fitted yet but I am going to spot weld them to inner wing before I fit it, was just trial fitting for now, the outer a panels are very good and using door to align them has worked out quite easy.
