Edited by Daz1968, 14 February 2016 - 11:51 AM.
Mk2 Cooper
#166
Posted 14 February 2016 - 10:58 AM
#167
Posted 14 February 2016 - 12:13 PM
A little update,
The pile of bits removed is getting bigger, although on this one I am bagging a labelling everything to make it easier in the future
How it stands at moment
Hopefully finish stripping it so I can survey the extent of body work required,
I have been looking forward to starting this one but know its a long hard road ahead.
Hi I noticed this project has only One Vin Tag on the o/s front inner wing .As i got a lot a grieve from my last M.O.T station infact had failed my Mini for not having Two Vin Tags .? does your front end have a print else where.
Edited by jcab, 14 February 2016 - 12:22 PM.
#168
Posted 14 February 2016 - 12:25 PM
Edited by Daz1968, 14 February 2016 - 12:26 PM.
#169
Posted 20 February 2016 - 05:42 PM
Fitted drivers side rear quarter, spot welded and tacked in position
Only had one issue the rear window corner doesn't match too well, think I will salvage a bit from the original panel I cut out and use the rear window to make sure all ok, not bad though really for a magnum panel. I could probably hammer it to shape but think it will be easier letting a piece in.
Then a quick picture of inside car, looking a lot better now it has new metal. I am really starting to feel confident that it's going right now.
Only other update is I have located a correct distributer and a few new old stock parts to help when putting back together,
#170
Posted 21 February 2016 - 05:35 PM
Drilled holes for rh tank bracket and welded bulkhead to arch
Fitted bootboard brackets
Trial fitted the new bootlid and spotwelded rear flange
Then just had a general tidy up but it is now starting to look like a car again
Hopefully get hole in rear panel for rh tank next week and weld more of the rear quarters
#171
Posted 21 February 2016 - 06:46 PM
You are making some great progress on this restoration. It is very nice to see. Soon it'll be time for paint :)
#172
Posted 22 February 2016 - 07:00 PM
#173
Posted 22 February 2016 - 10:56 PM
just been manic at work and home lately.
#174
Posted 23 February 2016 - 08:28 AM
#175
Posted 23 February 2016 - 05:00 PM
Daz this is exceptional. Keep at it - I want to see the finished product!!
#176
Posted 27 February 2016 - 06:13 PM
I slit the rear quarter and adjusted to correct shape, then welded in a few small pieces
Then I ground the welds on rear shelf, not perfect but much better than it was
Then fully welded rear quarters, linished the welds and checked for distortion as I went, they have turned out acceptable, need a little adjustment and filling but nothing I wasn't expecting
Then I spent a little time adjusting bootlid to get best fit I could, am pleased with the shut lines now,
Hopefully other than a bit of grinding and cutting hole in rear panel for rh tank the rear is complete, just need to get some more panels and start planning best way to tackle the front now, the front is the area I need to get right as it really shows a good or bad restoration.
Going to take my time and get it right.
#177
Posted 27 February 2016 - 06:51 PM
What panels have you got to do on the front ?
#178
Posted 27 February 2016 - 07:00 PM
I have a few bulk head repairs to do, then full heritage inner wings, inner and m machine outer a panels c/w door post, inner a post panel, wings and front panel. The front panel will be an m machine mk2 spec and I will be fitting the correct sized indicator plinths also from m machine, my bonnet is rust free, just has a little dent in it so will be repairing and retaining that, so have plenty to keep me busy.
Although I actually prefer this part of the restoration.
#179
Posted 27 February 2016 - 07:11 PM
#180
Posted 28 February 2016 - 05:20 PM
Drilled out the spot welds
Removed the old inner and outer a panel
The inner panel will be replaced after I have spot welded the inner wings to outer a panel.
Then I trimmed to size although cut a little too much off one end, but not enough to cause a problem welding it as I can get some copper in behind
Overall I am pleased with this panel as it makes alignment easier and the job is also a lot easier to do
I will now tack in position and trial fit the door to check alignment.
Will get this welded in next week and hopefully repeat on other side, think I need to get my inner wings next week as will be needing them shortly
