Having Trouble Fitting Front Windscreen?
Posted 17 September 2015 - 04:26 PM
Posted 17 September 2015 - 04:47 PM
are you putting the glass in the right groove big groove glass small groove body you may have to twist the rubber inside out , will the rubber fit right around the glass if not its the wrong one
Posted 17 September 2015 - 04:53 PM
It may be worth cutting a few small sections from it to enable you to position the screen in the aperture to then enable you to check the gap is correct between the glass and the aperture, I believe it should be around 1/4" to 3/8" gap to allow the window seal to fit nicely.
Worth a check, just to make sure what the problem is being caused by?
Posted 17 September 2015 - 04:59 PM
Posted 17 September 2015 - 05:03 PM
Posted 17 September 2015 - 05:05 PM
hi mate I might test the glass in to see where it's tight I do think I have the thicker type from mini spares tho.Tom, have you any old window rubber about?
Posted 17 September 2015 - 05:07 PM
Posted 17 September 2015 - 05:51 PM
Have you got a new front screen or original as mk1 glass front and rear is thinner in thickness ? Just a random thought really ha
Posted 17 September 2015 - 06:22 PM
Its normal the rubber appears bigger than the hole, you need to ensure its pushed right in the corners.
Always fitted minispares ones with no issues whatsoever.
If youve had scuttle work, has it been welded wrong?
Posted 17 September 2015 - 06:33 PM
Posted 17 September 2015 - 07:32 PM
yes mate it buckles out in corners and it's the original glass the one I took out I am pritty sure my original rubbers was small in thickness cheers TomWhen fitting the rubber to the aperture, I find it's important to make sure you don't stretch the rubber as you fit it, and the same goes for the rubber type insert . I think if the rubber is to long it would buckle out in the corners (on the inside when fitted to the aperture , did you notice it do that when you tried to fit it?
Posted 17 September 2015 - 07:34 PM
hi jordie I welded a new scuttle as well as new front end I went to the original dash metal no higher or lower?Its normal the rubber appears bigger than the hole, you need to ensure its pushed right in the corners.
Posted 17 September 2015 - 07:35 PM
hi yes new scuttle was fitted thanks TomHave you had any work on the scuttle?
Posted 18 September 2015 - 12:15 PM
I believe what is in order is to make some measurements of the repaired opening and compare those with measurements for a Mini which has no scuttle repairs.
