Alarm/ Immobiliser 1995 Spi Sidewalk
9 replies to this topic
#1 Simon1867
Simon1867
  • 157 posts
  • Local Club: Southern Mini Owners Club
Posted 13 September 2015 - 06:03 PM
Need abit of help,
I'm fairly new to spi and the rover alarm system. I have a 1995 sidewalk with the factory fitted alarm, just recently it has started not deactivating when I press the button, sometimes it does sometimes it doesn't, I'm assuming the key fob battery is flat.
I have read a few threads on here so apologise if this is going over old ground but I can't find my answer, when I purchase the car it didn't come with the original hand book and I've read that you need that to know a sequence to re-program the fob.
The car is completely standard and nothing has been changed.
Can anyone help, does any one have a spare or second hand rover hand book for sale?
Thanks for your help in advance.
#2 CityEPete
CityEPete
  • 3,920 posts
Posted 13 September 2015 - 06:52 PM
Is it a one or two button fob? I can pm you the instructions to programme the single button if needs be.
#3 Simon1867
Simon1867
  • 157 posts
Posted 13 September 2015 - 08:47 PM
It's the 2button fob, if you have the instructions for a 2fob that would be good. Thanks.
#4 FlyingScot
FlyingScot
  • 2,664 posts
Posted 13 September 2015 - 08:57 PM
For two button fob - 5AS alarm unit.
Replace battery in key fob with new CR2032 of decent quality like Duracell.
Press lock button (left hand one from memory) 4 or 5 times one after another to sync with alarm box.
SPiguy tells me the left one is unlock (see below)
If it is duff there are places on eBay and similar which refurbish them (the solder cracks around the switches normally with age).
FS
Edited by FlyingScot, 13 September 2015 - 09:42 PM.
#5 spiguy
spiguy
  • 1,537 posts
Posted 13 September 2015 - 09:39 PM
FS, I don't like to question your knowledge on these matters but... I think it is the unlock (which is the left hand one with the keyring hoop nearest you, it is also smooth whereas the lock on has bumps on it). I just fired up my 95 SPi cooper recently and I replaced both fobs batteries, and I pressed the unlock 4 times to sync the fobs. I heard the click of it unlocking on the 4th press.
#6 FlyingScot
FlyingScot
  • 2,664 posts
Posted 13 September 2015 - 09:42 PM
Ha ha your right, it's the left hand one but I had it in mind that was lock....
The memory isn't what it was....
FS
#7 CityEPete
CityEPete
  • 3,920 posts
Posted 14 September 2015 - 09:29 AM
I know the AS alarms aren't great but could this thread be removed once the OP has the correct info?
#8 spiguy
spiguy
  • 1,537 posts
Posted 14 September 2015 - 10:18 AM
This is only instructions on how to re-sync fobs, which are already paired with the system, after replacing batteries. It doesn't allow you to just get any old fob and sync it to the AS, you need software and hardware to do that, so there isn't a security issue here.
#9 CityEPete
CityEPete
  • 3,920 posts
Posted 14 September 2015 - 12:34 PM
Not for the 3AS you don't although the programming is different to what has been said.
#10 Simon1867
Simon1867
  • 157 posts
Posted 14 September 2015 - 02:35 PM
I have the information I need, thanks everyone for your help.
Mods if you want to delete this thread as people are worried about security then that's fine by me....last thing I want is peoples cars going missing.
Thanks again everyone.
