so I've been a bit slack with the updates due to work and bits, so recently the loom turned up from specialist components along with their GDI4 ECU well happy with the loom etc
so ive sent a bit of time getting the relay and fuse boxes wired in, got everything powered up, just trying to wire up the throttle pedal properly tomorow then it should be ready to see if it runs.
Here the fuel tank we made its baffled and filled with foam to avoid fuel surge etc, absolutely gutted i forgot to take photos of it before it was welded, but its slighty larger that the std estate tank but fits in the std location..
prior to this we mocked up the intercooler pipework and intake pipe....
now the intake pipe
thanks again to nigel with his welding on these
then...
then last of all i got the coolant pipes made and tacked in place then mounted the water pump and expansion tank
hoping to try and get it running this weekend
