Polishing A Turd - Fuel Injected 1380Cc Mini Clubman
221 replies to this topic
#61 Vinay-RS
Vinay-RS
  • 2,114 posts
Posted 29 May 2016 - 10:23 AM
Wow, that whole brake assembly is gorgeous.
#62 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 29 May 2016 - 12:28 PM
Are those original minifins not for the front?
#63 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 29 May 2016 - 12:57 PM
No, there's no difference.
#64 Gr4h4m
Gr4h4m
  • 1,802 posts
Posted 29 May 2016 - 06:04 PM
I thought there was... If they are original.
#65 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 30 May 2016 - 06:58 PM
Bit of an update. Not as much as I'd have hoped after a 3 day weekend, but I'm still quite a few parts short of making good progress.
First up I fitted a new pair of door mirrors. They're the larger type fitted to Clubman estates and Metro vans. The small ones I'd originally fitted we're absolutely useless and didn't fill me with any confidence when driving. Not only are these massively improved they fit well with the standard sleeper look I'm going for.
I've actually got a NOS set of these in their original Rover boxes stashed away with some other nice NOS external parts but I don't want to fit them until I get the car resprayed next year so these are just a good condition second hand set for now.
Next up I made some progress putting the front subframe together for the final time after a lot of trial fitting with my weird suspension set-up. I couldn't finish it though as I stupidly split a rubber boot on one of the knuckle joints.
One thing I did address was the lock washer on my adjustable bottom arms. When I took them apart I wasn't happy with how they'd distorted so I had a pair laser cut from thicker 4mm stainless with a slightly larger outside diameter.
My crank, clutch and flywheel finally came back from being balanced this week after a massive wait from my local engineering place which meant I could get started putting the engine back together.
The 1380cc MPI block's been honed, had a very light skim and new cam bearings pressed in. The crank's been wedged and had a 20/20 regrind and then the two were mated together with a centre main cap and ARP bolts.
After checking the crank and primary gear end float I've fitted a new Swiftune SW5-07 and their competition CNC'd oil pump along with a set of correctly ground followers from Calver ST.
That's as far as I got for now. I'm waiting on a set of Total Seal piston rings coming from America before I can continue and I noticed today some of my engine paint is flaking off so I need to address that as well before I get any further into the build.
#66 Gr4h4m
Gr4h4m
  • 1,802 posts
Posted 31 May 2016 - 03:50 PM
Nice looking crank
#67 MrBounce
MrBounce
  • 2,641 posts
Posted 31 May 2016 - 04:07 PM
This is such a fantastic thread. Love it!  :thumbsup:  :teehee:
#68 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 04 June 2016 - 08:10 AM
Nice looking crank
Thanks guys.
#69 GraemeC
GraemeC
  • 7,437 posts
Posted 04 June 2016 - 08:19 AM
Unusual centre main strap - where's it from?
#70 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 04 June 2016 - 08:31 AM
So, the final issue I had to sort as a result of moving the top arm was the shock absorber. A quick look under the car showed there's no way I could mount it in the standard position with the top arm being moved inwards by 8mm without it fouling on something.
Not a problem, I've never liked the angle the shock absorber sits at and always intended to mount it in a pair of coil over style brackets instead.
I did some calculations to work out where I thought a set of standard height shock absorbers would sit and drew up a template on the computer. Using the centre line as a reference I stuck them onto a piece of 80mm x 80mm x 5mm box section steel and cut them out.
They actually turned out much better than I thought they would  :D
After a couple of coats of POR15 paint I sorted a set of high tensile bolts where the unthreaded shoulder runs the full width of the mounts.
From memory the upper and lower mount are slightly offset from each other, but I couldn't remember by how much so I had a whole load of spacers laser cut in 4mm, 6mm, 8mm and 10mm thick stainless steel. Using a combination of these I should be able to perfectly align the shock absorber in the two mounts once they're on the car.
#71 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 04 June 2016 - 08:33 AM
It's a nice piece of kit, CNC'd from K600 tool steel by Elmer Racing in Finland. Unfortunately the shipping was almost as expensive as the actual strap!
http://elmerracing.c...ring-cap-detail
#72 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Posted 04 June 2016 - 12:13 PM
Looking like good progress to me, my idea of slow progress is getting out there with a cup of tea prodding around a bit and not actually achieving anything other than giving myself another shopping list and very little in the way of solutions to the various problems to over come!
#73 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 05 June 2016 - 01:47 PM
Built up my drive assemblies this morning.
NOS Metro hubs with Timken bearings, KAD 7.9" non vented callipers with Mintex 1144 pads and Minispares competition drive shafts.
Edited by podifold, 05 June 2016 - 01:48 PM.
#74 Rocket.
Rocket.
  • 1,441 posts
Posted 05 June 2016 - 03:01 PM
Awesome build !
Love the idea of this !
#75 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 06 June 2016 - 12:17 PM
I must ashamedly admit that despite being a member of the TMF team I only very rarely post and even then it's usually to update my own progress thread. However after stumbling across this build thread I really just wanted to share how much I'm enjoying reading your progress with this. It's always so inspiring to see someone going the extra mile to get the best out of something.
I especially like the movement of the top arm to accommodate the metro hubs. Mini ball joints are not my favourite either, I'm never sure they're just right.
Looking forward to further updates and hope to see the Clubman or your Pickup around (I'm fairly local).
