Polishing A Turd - Fuel Injected 1380Cc Mini Clubman
221 replies to this topic
#31 rhys-89
rhys-89
  • 1,549 posts
  • Local Club: minifreekz
Posted 24 April 2016 - 06:17 PM
Love the pic looks like it was taken back in the day lol
#32 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 26 April 2016 - 08:26 AM
Reading your subframe mods with great interest.  The bump stop angle is the only thing limiting me from going lower at the front and this seems to sort that out perfectly.
#33 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 26 April 2016 - 01:30 PM
I think I saw your clubby in stockport the friday before last..... near the A6...
#34 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 26 April 2016 - 01:44 PM
Yep, that was probably me  :-)
#35 minimissions
minimissions
  • 3,427 posts
Posted 27 April 2016 - 05:48 AM
haha cool, nice to see another in the area, you local to Stockport?
#36 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 04 May 2016 - 10:34 AM
Yeah, I'm in Stockport  :-)
#37 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 04 May 2016 - 10:49 AM
So, here's my cut down Hi-lo.
I wanted to make sure I didn't affect the strength of the unit so this is currently my "safe" option. I had a friend lathe 5mm off the main body and 12mm of the main adjusting bolt, completely taking the hex head off and a bit more.
I consider this the safe option because:
  • The top of the main body is heavily chamfered inwards so although I've taken 5mm off it I've actually only lost around 2mm of threaded contact area between the main body and the adjuster bolt.
  • I'm still using the lock nut which I think is essential.
  • The shoulder of the knuckle joint still has it's full contact area touching the adjuster bolt even with the hex head removed.
The new Hi-lo sits 12mm shorter than the original which should give me enough room to get everything in. If not I'll have to look at other options.
#38 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 04 May 2016 - 10:56 AM
Oh, and I can still adjust the height using a length of hex bar passed through a pair of drilled tower bolts.
#39 cooperS
cooperS
  • 116 posts
  • Local Club: MOC Santiago, Chile
Posted 04 May 2016 - 12:07 PM
i saw that same mode on some Japs Minis! incredible way to get the correct ride height
#40 giannoutsos
giannoutsos
  • 58 posts
Posted 05 May 2016 - 09:01 AM
Pretty clever that,
Nice modification
John
#41 Baldspeed Racing
Baldspeed Racing
  • 1,193 posts
Posted 05 May 2016 - 09:13 AM
nice mods to the hi-los defo gonna give a lot more tweaking options given the ratios between trimming them down to ride height if that makes sense
#42 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 05 May 2016 - 04:43 PM
Got a few more small jobs sorted today.
Both subframes are now off the pick-up and have been dropped off for sand blasting.
I've mounted the coil pack where I want it on the bulkhead so that I can have a drive over to Magnacor and have them measure up and make a custom set of HT leads the right length.
And lastly I've welded a bracket in the boot for the washer bottle as there'll be no room for it under the bonnet once the supercharged engine's in there.
#43 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 06 May 2016 - 07:06 PM
Today there was lots of grit blasting. Which I hate.
#44 DannyTip
DannyTip
  • 1,020 posts
  • Local Club: A Series Magpies
Posted 06 May 2016 - 07:30 PM
Blasting is a horrible job but it goes the job done.
What are the two brackets in the middle?
#45 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 06 May 2016 - 07:34 PM
Intercooler mounts.
Edited by podifold, 06 May 2016 - 07:40 PM.
