A-Panel Welding
6 replies to this topic
#1 MiniMoe2008
MiniMoe2008
  • 166 posts
  • Local Club: None Around Here
Posted 05 September 2015 - 10:19 AM
Hello All,
    So I just finished installing the flitch panels on my mini and want to press with the scuttle and A-Panels. Does anyone have good pictures of how the A-Panels are welded at the top and bottom? The flitch panels didn't line up well until I hammered and beat them into shape.I had to cut some excess metal but I just want to make sure its lined up correctly. Any pictures or a good description on how they did it would be greatly appreciated. Thanks again!
#2 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 05 September 2015 - 10:23 AM
http://www.theminifo...rebuild/page-59
Hope that helps
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,076 posts
  • Name: Neil
Posted 05 September 2015 - 10:52 AM
The one thing i do with  the A panel especially at the top is to seam weld along the top edge then carefully shape it with a carbide bit to get the contour line. Several spot welds or plug welds down the back of the A panel edge then at the bottom where it sits on the doorstep another plug / spot weld. On the inside of the inner wing where the A panel butts against the flitch return this is then cleaned and seam sealed.
#4 MiniMoe2008
MiniMoe2008
  • 166 posts
Posted 07 September 2015 - 04:30 PM
Thanks guys for sharing!!! You're both life savers!
#5 Blatherskite
Blatherskite
  • 501 posts
  • Local Club: Norsk Mini Cooper Club
Posted 01 October 2015 - 06:18 PM
IMG_3435_zps6cce2be6.jpg[/url]
There's a shutline to be proud of. Must have taken hours to get it like that!
#6 sonikk4
sonikk4
  • 16,076 posts
  • Name: Neil
Posted 01 October 2015 - 07:09 PM
Little bit more to that than meets the eye though. Adding metal to the edge of the door or A panel to get the even gap. A bit like this
#7 myminipickup
myminipickup
  • 152 posts
Posted 01 October 2015 - 08:33 PM
Hi,
Following on from this - does anyone have any pictures or description of how the A panel and inner A panel are put together and welded on a Pickup (or MK1 Mini) please? I can't really work out how the inner A panel is put onto the inner wing/front bulk head, and how the outer A panel is then welded onto this.
Many thanks
