I seem to be getting the occasional clutch judder when pulling away in 1st or reverse. Sometimes its really bad, sometimes it doesn't do it at all, and sometimes its somewhere in the middle! If I rev the engine up to 1500 revs when pulling away then its fine.
Reading through the forum, the general consensus is that oil on the clutch is the reason for this, and a tell tale sign of that happening is oil leaking from the split pin at the bottom of the clutch. However the split pin on mine is bone dry.
Also my engine mounts seem fine as well, so what else can cause a judder when pulling off?
