Cool thanks of the replies guys,
looks like ill be hunting down a cheap gas welder my next question was going to be about the best type of gas and where to buy it but that seems to of been answered as well so thanks, hobby weld it is
Posted 01 September 2015 - 07:35 PM
Posted 01 September 2015 - 07:44 PM
Gas mig welders are the way for thin sheet steel, one thing with the gas, I switched from pub CO2 bottle as I read up on the mig welding forum that argon/CO2 mix is better to use, BUT beware, my new bottle from hobbyweld only lasted 2 weeks, my co2 bottle lasted years so I'm going to swap back once this new bottle runs out. I got told when enquiring why it had run out so fast that they are just for use for small jobs etc not for every day use which I thought was a bit out of order, its as if they fill the bottle to just shy of 2000psi as my gauge has already moved from that after only a few hours use, anyway I'd go for pub co2 bottle
cheaper refills too
eean was it the Hobbyweld 5 gas that your using at the moment?
Posted 02 September 2015 - 07:14 AM
Edited by eean, 02 September 2015 - 07:18 AM.
Posted 02 September 2015 - 09:22 AM
I have this model
http://www.ebay.co.u...=item4aefad6817
I can't recommend it enough. Quite old now but spares are plentiful and they are very nice to use.
(that's not mine for sale by the way)
Posted 02 September 2015 - 09:38 AM
It is yes, it doesn't last long if you use it a lot lol, I run it at around 6-8 psi when using in a non windy area luckily in my garage, make sure your gauge is a twin dial one which shows you how much gas is left in the bottle, even when it registers empty there's still quite a bit in on mine at least
Oh when you look at seconds hand mig setups see if you can get a fan assisted one they run cooler and you can weld for longer without it tripping to cool down, they usually call them turbo migs
You either have a leak or your not comparing like with like, gas is gas, whether you have CO2 or Argon/CO2 coming out the nozzle at 6-8psi.
I use soapy water to test the connection and I always turn off the main tap when I'm finished welding. I also check the bottle with a gauge before removing from the suppliers as I have found in the past that the bottle may not be as full as expected
David
Posted 02 September 2015 - 03:21 PM
David
I use my welder a lot and the last bottle i got was half price because there was a problem where hobbyweld supplied the supplier with half full bottles.
I have had it months now and it's just creeping down to the empty on the gauge.
Posted 02 September 2015 - 04:38 PM
David
Posted 02 September 2015 - 04:54 PM
+1 on leaks - & soapy water for finding them
I always set my gas as low as possible without getting oxide to make the gas last longer
also make sure no drafts , as the shield gas is easily blown away
the gasless wire is good for outside welding , as wind can be a problem
another problem is the larger regulators with gauges , can get knocked , the gauges are weak & can get adjusted by the knock
then if you are setting flow by these gauges you may be over gassing , I always set the gas by sound , should be just a gentle flow
I usually use cougar - co2 & argon shield
tank pressure is usually psi/bar , line is usually Litre per min
Edited by sledgehammer, 02 September 2015 - 04:55 PM.
Posted 02 September 2015 - 04:58 PM
Posted 03 September 2015 - 09:10 PM
So after reading all these comments i've just bought one which comes with a small disposable CO2 cylinder which can be used as gas or gas less but I'm going to keep it set up as gas as the comments suggest it gives the best weld???
Next question is can i easily convert it to take a large bottle? Is it just a simple as buying a bigger regulator?
Posted 03 September 2015 - 09:37 PM
This kit will have what you need
http://www.ebay.co.u...=item2101625625
the small gas tube comes off the disposable cylinder reg by pulling back a collar where it fits to the reg.
Then on the adapter hose for the new reg, there is a fitting with a collar and you just push the small hose into it. It's just a push fit
Posted 03 September 2015 - 09:54 PM
Sweet cheers Ben
