Mini Is Terrible In The Rain
25 replies to this topic
#1 Corey96Williams
Corey96Williams
  • 316 posts
Posted 22 August 2015 - 06:35 PM
Hi,
My Mini is shockingly bad in the rain. So bad when it starts to rain I feel nervous going out in it. I believe it's the spark plugs getting wet. I have done the glove over the distributor trick, but unfortunately it's not enough.
What else have you tried or used? I've come across a sort of spark plug dryer and sealer in SparesWorld a few months back for around £3, is that any good? Also I don't have one of those covers (that go over the plugs) that are apparently standard.
Any tips appreciated :)
Thanks,
Corey.
#2 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 22 August 2015 - 06:39 PM
Plugs dont come with covers, the never did... Your best bet is to upgrade to electronic dizzy
#3 Artstu
Artstu
  • 830 posts
Posted 22 August 2015 - 06:41 PM
You answered your own question there. http://www.minisport...-and-clips.html
#4 Cooperman
  • 23,276 posts
Posted 22 August 2015 - 06:45 PM
The Mini is not basically bad in the wet. In fact think of all the rallies the cars have done in streaming wet weather, through deep fords and on flooded lanes.
The best way to seal it is to buy a tube or can of silicone grease. I use the grease they use to grease the control cables on light aircraft as it is totally non-conductive.
Liberally plaster it all over the dizzy cap, the coil connections and the plug leads. Then spray with aerosol ignition sealer and allow it to dry. It will then not fail in the wettest of weather.
#5 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 22 August 2015 - 06:46 PM
I would Get or make one of the above covers, they can be bought cheaper than that or made for free like mine.
Edited by alex-95, 22 August 2015 - 06:53 PM.
#6 Spider
  • 14,838 posts
Posted 22 August 2015 - 06:47 PM
Good quality leads will make a world of difference.
#7 Corey96Williams
Corey96Williams
  • 316 posts
Posted 22 August 2015 - 07:12 PM
https://www.google.c...zqFQeVWSOf3ztM:
That was what I meant. Positive they were standard at one point. Mine is a '95.
#8 Corey96Williams
Corey96Williams
  • 316 posts
Posted 22 August 2015 - 07:14 PM
Stupid question, what is that made out of?
Edited by Corey96Williams, 22 August 2015 - 07:17 PM.
#9 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 22 August 2015 - 07:25 PM
Theyve never been standard!
#10 mab01uk
mab01uk
  • 12,412 posts
Posted 22 August 2015 - 07:29 PM
The plastic engine splash shield was a standard factory fit from sometime in the 1970's onwards to stop wet ignition leads and distributor........the fixing brackets are often still in place but the plastic covers get lost or not re-fitted over time.
Edited by mab01uk, 22 August 2015 - 07:31 PM.
#11 Corey96Williams
Corey96Williams
  • 316 posts
Posted 22 August 2015 - 07:33 PM
If you say so!
#12 Spider
  • 14,838 posts
Posted 22 August 2015 - 07:37 PM
Not raining here, but wet all the same
#13 Corey96Williams
Corey96Williams
  • 316 posts
Posted 22 August 2015 - 07:46 PM
The girl in the background looks confident...
#14 alex-95
alex-95
  • 6,025 posts
Posted 22 August 2015 - 07:50 PM
Corrugated plastic that come off a pallet, Mine goes down just below the top of the front panel.
#15 jb93
jb93
  • 2,439 posts
Posted 22 August 2015 - 07:59 PM
Leccy ignition :thumbsup:
