Put the tyre sizes in a calculator to compare the diameter. http://www.tyresizec...tire-dimensions
I've had 155/70x12 tyres on the Midas in the past, and also had them on a Mini too. 165/70 is pushing it though.
You'd probably be better focusing on the suspension. For example most adjustable (if not all) hi lows have a larger diameter surface acting on the rubber doughnut, which I'm lead to believe increases the effective spring rate.
Aaahh, I didn't realise that the wider the tyre the bigger in diameter it became. I always thought that for the same profile and wheel size the diameter of the tyre remained constant.
I've gone back to look at the link I put in from Guessworks re. tyres suitable for mini rims. This paragraph in particular:
'Falken FK-07E 165/70R10 Rim Width 4.00" to 5.50"
Falken FK-07U 165/70R12 Rim Width 4.00" to 5.50"
Falken FK-06G 165/60R12 Rim Width 4.50" to 6.00" '
Perhaps the suffixes E, U and G refer to tyre height or overall diameter. I tried looking on the Falken website but couldn't find any info, and Google couldn't help
