Fitting The Radius Arma To The Subframe
Best Answer JonnyAlpha , 22 August 2015 - 08:03 PM
Last pic:
Go to the full post
8 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,749 posts
  • Local Club: Exmoor Minis
Posted 22 August 2015 - 02:57 PM
Hi fellas and felleses;   Quick question, when fitting the Radius Arms to the Subframe where do the large washers go, between the Radius Arm and the Subframe or Camber Bracket or on the other side of the Subframe or Camber Bracket.   I have searched for a few pics and it looks like the go on the inside butted between the Radius Arm and Subframe / Camber Bracket and on the other side is the nut and spring washers??   Thanks
Edited by JonnyAlpha, 22 August 2015 - 07:32 PM.
#2 Ginge620
Ginge620
  • 86 posts
Posted 22 August 2015 - 03:00 PM
Inside butted to radius arm with the swirly pattern towards the arm then the rubber seal goes over.
What it looks like on my car
Attached File  IMG_20150822_160209.jpg   22.44K   23 downloads
Edited by Ginge620, 22 August 2015 - 03:05 PM.
#3 JonnyAlpha
JonnyAlpha
  • 2,749 posts
Posted 22 August 2015 - 03:12 PM
Sorry still not quite clear, so the Large Washer and Spring Washer go on the outside and there is nothing between the Radius Arms and the metal on the Subframe or the Camber Brackets??? This means that there is nothing between these moving parts?
#4 Ginge620
Ginge620
  • 86 posts
Posted 22 August 2015 - 03:17 PM
Radius arm -> big washer (rubber seal around) -> subframe or bracket -> spring washer -> nut
Edited by Ginge620, 22 August 2015 - 03:18 PM.
#5 Ginge620
Ginge620
  • 86 posts
Posted 22 August 2015 - 03:27 PM
Another pic, hope the helps.Attached File  IMG_20150822_162645.jpg   31.28K   30 downloads
Might be a little confusing from the previous pic because I have and extra washer before spring washer. Came part of a stainless kit.
Edited by Ginge620, 22 August 2015 - 03:36 PM.
#6 Cooperman
  • 23,568 posts
Posted 22 August 2015 - 03:51 PM
The large washe has the rubber seal around the outside diameter and it fits between the end of the arm and the bracket. If it didn't the arm would not fit correctly and would slide along the radius arm pin. The rubber seal is to keep the DGS out of the arm.
#7 JonnyAlpha
JonnyAlpha
  • 2,749 posts
Posted 22 August 2015 - 04:06 PM
Thanks guys - seem to have lost my rubber seal!!!! DAMMM
#8 JonnyAlpha
JonnyAlpha
  • 2,749 posts
Posted 22 August 2015 - 08:01 PM
Found the old ones in a plastic tub, good job I never throw anything away, perfectly serviceable. Everything went together OK too.
Inside of LH Radius Arm with seal fitted:
Outside of LH Radius Arm with seal in place:
Tightening up the lower bolt on the Camber Bracket, more access when lifting the Radius Arm up:
And job done:
As I was packing up I noticed that I had forgotten to fit the wheel studs, so off with the rear hubs as I don't think they'll fit in behind?
#9 JonnyAlpha
JonnyAlpha
  • 2,749 posts
Posted 22 August 2015 - 08:03 PM   Best Answer
Last pic:
