Our website has been down for 2 days in the last 2 years as we have applied the required magento updates, it is back up.
We unfortunately cannot monitor forums every day - most of my time is spent on the rollers or in the engine dyno testing and developing new control systems for our range of ECUs - when you called, I was actually mid mapping - we don't supply a diode kit, I knew trigger wheels did so I pointed you in their direction, an easy one fit solution instead of banging your head against a wall learning electronics to solve a problem - for £14 I was offering you a solution, it wasnt even £14 I was earning, but it SHOULD of got you up and running, as it is sold as a diode kit to have older style rev counters working with wasted spark ignition, which is exactly what the NODIZ (and the megajolt) are.
Now, it obviously hasn't worked, and I can assure you the same would be as with a megajolt - you have given trigger wheels your money, why are they not helping? Remember: The point you attached this diode kit (ie at the coils) is the same regardless of the ECU running it.
First you need to get an accurate pinout of your tacho, AND an understanding of how it works electronically - once you present that information to me I can tell you what needs to be done to make it work - that's my job as an electronics engineer after all - however - there's that age old grey line whereby how far does our support *need* to go - yes, we can and do help, but without the right information you are asking me to invest hours of time solving what appears to be a one off problem - a problem that should of been solved by the diode kit you have purchased, from someone else...
Is it not easier to just recore the tacho??? Send the diode kit back, it doesen't do the job you need it to.
There are also lots of guides out there on the web (I did a 3 minute search and found that post above), but you do need to have accurate data on what YOUR tacho needs to work, or we are all the dark...
The fact it is dropping off at higher RPMs tells me that the problem may be down to the dwells of the coils overlapping (they shouldn't be at 3,000rpm, so its most likely a duty cycle requirement of the tacho) and hence its failing to register the pulses thereafter.
Another google search reveals... (I sued the keywords I gave to you of rev counter relay coil)
http://www.brumster....p?article_id=10
Give that a go - it might just work, and if it does, excellent, result!
Either way, keep me posted, we are always available on the phone - there are in fact five of us here in total - and although you may of felt rushed off, you were not, so sorry if that's what you thought.
Matt
