Oil Spraying From Exhaust
engine
Best Answer sledgehammer , 19 August 2015 - 09:53 AM
may be just soot & water , will be black like dirty oil
is it blowing blue smoke out of exhaust ?
mini's do like to mark their territory's
Go to the full post
8 replies to this topic
#1 TonyAlonG
TonyAlonG
    Just On Tickover
  • 8 posts
Posted 19 August 2015 - 09:22 AM
Hello everyone. I have a little, but annoying problem when I start my Mini Mayfair from cold; when I pull the choke, oil sprays out from the exhaust for a few seconds. The big problem with this is that I have ruined my new driveway!  :ohno:
The oil level is just between minimum and maximum and I have never experienced any oil leaks from the engine bay.
If anyone has any advice, please let me know as soon as possible.
Thank you and have a good day.
#2 Mini Manannán
Mini Manannán
  • 2,856 posts
  • Local Club: man Estate
Posted 19 August 2015 - 09:50 AM
Do you mean it sprays out of the exhaust tail pipe or from the manifold?  What type of mini, year, modifications?
#3 sledgehammer
sledgehammer
  • 3,098 posts
Posted 19 August 2015 - 09:53 AM   Best Answer
#4 spiguy
spiguy
  • 1,537 posts
Posted 19 August 2015 - 10:04 AM
Yeah, I doubt it would be oil - more likely to be soot and water making a dirty wet spray. Any oil getting into a running engine would be burned and would come out as blue clouds of smoke.
#5 rally1380
rally1380
  • 1,893 posts
Posted 19 August 2015 - 10:06 AM
Mine does the same.....but you might find it is not oil.  When I was much much younger, my first mini used to blow black sooty liquid all over my bosses car on start up....also used to set his car alarm off.....was such a laugh!!!!
As sledgehammer above says, it might be just soot and water.  Check for blue smoke from exhaust, also check the plugs - if plugs are oily then it might point the direction of worn rings or valve guide/seal.
#6 Cooperman
  • 23,278 posts
Posted 19 August 2015 - 10:36 AM
All Minis do that. It's the water from the exhaust washing the carbon deposits from the inside of the exhaust pipe.
#7 TonyAlonG
TonyAlonG
    Just On Tickover
  • 8 posts
Posted 19 August 2015 - 11:16 AM
thanks to everyone who replied really quickly, now i know its only soot and water
#8 A-Cell
A-Cell
  • 1,610 posts
Posted 19 August 2015 - 12:30 PM
Take it out for an Italian tune up!
Give it a nice fast open road run to fully heat up the exhaust and clear out the carbon build up.
#9 spiguy
spiguy
  • 1,537 posts
Posted 19 August 2015 - 12:54 PM
Don't worry, you'll get some oil coming out, just it won't be out the exhaust rather it will be out the engine and on to your drive :lol:
