What Temperature Does A Manifold And An Exhaust Get?
11 replies to this topic
#1 rodandtom
rodandtom
  • 998 posts
Posted 13 August 2015 - 07:49 PM
Hi,
I wanted to paint my manifold and my exhaust. I've got some 800 degree C paint, would that do it?
Rod
#2 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 13 August 2015 - 07:54 PM
You can spend as much on engine paint and high-temperature paint as you would like.
In my experience, high-temperature exhaust paint has very little binder in it so it looks great until the hot pipes are splashed with water and/or the engine is washed.  Then the coating flakes off and you are back to where you started.
Your 800 oC paint may be formulated differently and be better.  It certainly has a high enough heat rating.  However, if you don't mind black, paint for refinishing barbeque grills/cookers works very well and has sufficient binder to stay in place.
In answer to your question about exhaust temperature, there is no single answer.  That depends highly on the mixture and tuning of the engine as well as how hard the engine is being pushed.  It is not unheard of for lean mixtures to get exhaust headers glowing cherry red.
#3 Spider
  • 14,849 posts
Posted 13 August 2015 - 07:56 PM
That should be fine.
#4 rodandtom
rodandtom
  • 998 posts
Posted 13 August 2015 - 08:13 PM
This paint I'm using is for BBQs. It's silver if you are interested.
Rod
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 13 August 2015 - 08:37 PM
Hopefully that paint has more binder than the stuff you buy specifically for manifolds.  Let us know how it works for you.  I am interested in hearing your results.
#6 Spider
  • 14,849 posts
Posted 13 August 2015 - 08:48 PM
I've use the VHT Brand of paints for the manifolds, I've found them rather good.
http://www.vhtpaint....cts/flameproof/
But like anything, preparation is everything.
They also used to have Ceramicoat Kits, basically a Ceramic Paint, I've used it on alloy head combustion chambers and piston crowns with really good results, but they seemed to have dropped these kits from their range now. These were also really good on exhaust systems, just a bit pricey though for something like that.
#7 timmy850
timmy850
  • 3,330 posts
  • Local Club: MITG
Posted 13 August 2015 - 11:28 PM
It's hot enough to give your finger a bloody good burn. Ask me how I know !
#8 Dusky
Dusky
  • 5,322 posts
Posted 14 August 2015 - 08:38 AM
My 998 with retarded ignition got cherry red in a few minutes idling :')
#9 Spider
  • 14,849 posts
Posted 14 August 2015 - 09:03 AM
Yeap.
Read this one through
http://www.theminifo...wrap-yes-or-no/
#10 One step at a time
One step at a time
  • 282 posts
Posted 14 August 2015 - 09:44 AM
(How do you know)??????😂
#11 madaboutcherry
madaboutcherry
  • 539 posts
  • Local Club: no
Posted 14 August 2015 - 11:00 AM
how do you know? :D
#12 finch661
finch661
  • 2,339 posts
Posted 14 August 2015 - 11:31 AM
I have a thermal camera, will try and get a pic or reading (of mine anyway :) )
