Revs Itself Slightly On Tick Over
13 replies to this topic
#1 minimadmarc2015
minimadmarc2015
    Just On Tickover
  • 9 posts
Posted 12 August 2015 - 09:03 PM
hi can any 1 help me I have a 94 spi mini it as recently developed a tick over problem it revs itself on tick over and the 2 little breather pipes on front on manifold the right hand pipe I can hear air sucking through it and if I squeeze the pipe it stops and tick over goes normal I have checked for air leaks and split pipes but all others are ok if I squeeze any other pipe it doesn't change it is just that 1 on manifold any help or advise would be greatful thanks
#2 cal844
cal844
  • 9,619 posts
  • Local Club: TFMOC
Posted 12 August 2015 - 09:09 PM
Which pipe? Can you post a pic of it??
#3 peter-b
peter-b
  • 773 posts
  • Local Club: still looking
Posted 12 August 2015 - 09:25 PM
If something causes extra air to get in that shouldn't I.e. a crook brake booster, the engine management will try to correct it, possibly by bringing idle up. As mentioned by Cal844, picture or pictures of the hoses would help.
#4 minimadmarc2015
minimadmarc2015
    Just On Tickover
  • 9 posts
Posted 12 August 2015 - 09:26 PM
i will upload a pic 2moz it is the two on front bottom of manifold and go to the metal pipe that runs along back of rocker cover its the right hose
#5 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 12 August 2015 - 10:38 PM
I think he's referring to the crankcase breather pipes found on later minis.
#6 FlyingScot
FlyingScot
  • 2,661 posts
Posted 12 August 2015 - 10:42 PM
Moved to injection
FS
#7 FlyingScot
FlyingScot
  • 2,661 posts
Posted 12 August 2015 - 10:45 PM
As above its air getting in. Either you have an air leak in th hoses or pipe or the valve to the charcoal canister is open or an issue with the charcoal canister (under the wing above the shocker mount).
One or several of these is at fault.
FS
#8 minimadmarc2015
minimadmarc2015
    Just On Tickover
  • 9 posts
Posted 13 August 2015 - 05:06 PM
#9 minimadmarc2015
minimadmarc2015
    Just On Tickover
  • 9 posts
Posted 13 August 2015 - 05:07 PM
these are the pipes I am on about and the right 1 what my finger is on that is the 1 that I can hear air going through if I squeeze it that stops and revs go normal thanks
#10 minimadmarc2015
minimadmarc2015
    Just On Tickover
  • 9 posts
Posted 13 August 2015 - 06:13 PM
#11 minimadmarc2015
minimadmarc2015
    Just On Tickover
  • 9 posts
Posted 13 August 2015 - 06:15 PM
these are the pipes I am on about the right 1 is the 1 that air comes through and when I squeeze that it stops and the revs go normal thanks
#12 minimat
minimat
  • 690 posts
  • Local Club: anglian mini club
Posted 13 August 2015 - 07:58 PM
Replace the pipe,as already stated any air leak will confuse the ecu which will try to componsate for the extra air getting in by raising the revs hence the hunting up and down.
#13 minimadmarc2015
minimadmarc2015
    Just On Tickover
  • 9 posts
Posted 13 August 2015 - 08:00 PM
  • replace which pipe mate
#14 orac69
orac69
  • 72 posts
Posted 06 January 2025 - 11:10 AM
An old thread, but in case of future interest I had the same problem (slightly high tick over, revs wouldnt drop as they should when I came to a stop) and the issue for me at least was simply a sticking throttle cable.  Brand new one, nice and slippy, cheap fix, sorted.
I know air intake / vaccuum leaks are really common cause, but this is another simple thing to check.
Edited by orac69, 08 January 2025 - 02:10 PM.
