Just to check, when using the silicone vacuum tubing, do you still use elbows or just connect the tubing directly to the fuel trap, etc?
Posted 14 August 2015 - 11:52 AM
Posted 14 August 2015 - 11:59 AM
The pipe is normally flexible enough to not require the use of elbows. Providing the internal diameter of the pipe is around 3mm you should be fine with just the silicone tubing.
Posted 14 August 2015 - 12:25 PM
That's brilliant, thanks. I've found some on eBay with 3.2mm (must be the one you have mentioned previously so i'll order that up.
Thank you.
Posted 14 August 2015 - 12:32 PM
Posted 15 August 2015 - 09:06 AM
Posted 15 August 2015 - 11:38 AM
Have you checked the power is getting to the lambda sensor before you change it? It'll get expensive buying new bits to replace items that are working perfectly well.
Posted 15 August 2015 - 07:17 PM
If you suspect the lambda is causing a problem, then to test your theory just disconnect it. The car will run perfectly well with it disconnected, using an assumed reading. No point going to all the expense and hassle of replacing it to potentially find it wasn't the cause of the problem.
Posted 16 August 2015 - 10:25 AM
Posted 16 August 2015 - 08:04 PM
Have a read of these
http://www.theminifo...e-from-exhaust/
http://www.minifinit...hp?f=22&t=86339
This thread here talks about general injection problems and is very helpful.
http://www.theminifo...oint-injection/
Posted 16 August 2015 - 10:41 PM
As far as what disconnecting the lambda would achieve, if it is faulty and giving the ECU wrong information about the fuel mixture, then the car will fuel incorrectly. If you disconnect it, the ECU will assume a typical value in the absence of the signal from the lambda, and will fuel accordingly. If everything is working correctly, disconnecting the lambda will make very little - barely noticeable - difference to the running of the car. If however the lambda is faulty, the symptoms will dissappear if you disconnect it, it is a very quick and easy way to tell if there is a major fault with the lambda sensors operation.
I advised this to another SPi owner on here with an apparently rich running car, and as soon as he disconnected it the car ran fine, proving that the lambda was faulty. In his case it was reporting a false lean condition, resulting in the ECU increasing fuelling (wrongly in real terms) which caused the car to run rich.
Edited by spiguy, 16 August 2015 - 10:42 PM.
Posted 17 August 2015 - 07:43 AM
Posted 17 August 2015 - 09:25 AM
Incidentally, you can't just leave it disconnected if indeed it turns out to be the culprit, whilst the car will apparently run fine without it, it would be very unlikely to pass an emissions test. Also, it may over time affect the CAT since the assumed value the ECU uses in the absence of a good lambda signal errs on the rich side.
Craig
Posted 17 August 2015 - 09:50 AM
Posted 17 August 2015 - 11:05 AM
Posted 17 August 2015 - 11:13 AM
Thanks for all the great info, but I am not sure if I have sorted it.
I left the battery disconnected all night, reconnected it this morning and started it up left it running for 15mins and the temp gauge was sitting between red and middle. I then removed the spark plugs and cleaned all the black soot off each one and put them back.
Started it up again left it running for 20 mins checked the gauge again and sitting in the same position between red and halfway revs read 1000 on counter so not racing anymore, took number 1 and 4 plug out and no soot at all revved it and no black smoke, so does it seem that it has sorted itself with changing the vacuums and fuel trap, is it ready for a MOT now.
