Subframe Reinforcement
6 replies to this topic
#1 AndyFrenchMan
AndyFrenchMan
  • 39 posts
Posted 11 August 2015 - 03:08 PM
Hello,
I'm actually building a Mini and i'd like to get a better rigidity as it will have a powerfull engine. So I welded my front subframe where there are critical mechanical efforts.
I want to do the same with the rear subframe but I don't know where to weld sheet of metal.
Can anyone help me ?
Thank you, regards.
#2 Daz1968
Daz1968
  • 2,058 posts
Posted 11 August 2015 - 04:55 PM
I would think putting gussets in the corners would be more than adequate and if you really want to strengthen then cross brace it with some 25mm box section being careful to clear the battery box
#3 Artstu
Artstu
  • 837 posts
Posted 11 August 2015 - 05:16 PM
The rear legs on the front subframe could do with some reinforcement too.
#4 AndyFrenchMan
AndyFrenchMan
  • 39 posts
Posted 08 September 2015 - 02:12 PM
Hi, sorry for my late answer, i've been busy these times :/. So this is what I've done :
I think it's gonna be okay :D!
Edited by AndyFrenchMan, 08 September 2015 - 02:12 PM.
#5 Steve220
Steve220
  • 5,146 posts
  • Local Club: BMC
Posted 08 September 2015 - 02:28 PM
Those straps will have little to no effect apart from adding weight. The subframes themselves are pretty sturdy. To feel any benefit you'll also need to solid mount them to the car.
#6 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
Posted 08 September 2015 - 02:35 PM
The mini racers do not go overboard with reinforcement so i would bin the straps. They dont do anything as they are not supported in the middle so basically just extra weight. The gussets and extra weld should be more than enough for anything you add.
#7 nicklouse
  • 19,067 posts
Posted 08 September 2015 - 02:46 PM
but they could be good to aid a rear skid plate mounting or a rear diffuser.
