Wiring Help, Melted Wires And Random Plugs
16 replies to this topic
#16 phil hill
phil hill
  • 616 posts
Posted 08 August 2015 - 12:23 PM
Cool, so headlights are all sorted.  The bullet connections are fine so long as they are clean and corrosion free.  There are various methods people use to prevent corrosion from petroleum gel, contact cleaner and recently this stuff has become available : http://www.12voltpla...r-25g-tube.html
Yes oil pressure light circuit is simple, live with the ignition, through the lamp to the switch.  If there is no power at the white and brown connection to the switch then suspect the lamp.  Assume it's the gauges behind the steering wheel ??  Carefully pull the cover off the front, the clips are likely to be very stiff and difficult to get cover away cleanly.  Then you will see two screws on either side and another hidden on the top, remove the screws and gently pull the instruments forward.  There is a multi-plug for the electrics and the speedo cable connecting the instruments.  The lamp holders are on the back, quarter turn jobs with a miniature wedge base lamp in each.
You're getting there nicely.
Phil.
#17 monkey
monkey
  • 1,382 posts
  • Local Club: Diss Mini Club
Posted 08 August 2015 - 12:35 PM
Yep two clock dash behind the steering wheel, got a homemade dash in though, it's a right fiddle getting it in and out lol, will probably wait until tomorrow before I go back out.
Once I get in my head how the circuit works, it's not to difficult tracing it through :-)
Thanks again, I will report back once i have the dash out :-)
Steve
