Engine Mount
4 replies to this topic
#1 dondo
dondo
  • 128 posts
Posted 01 August 2015 - 01:50 PM
Just a quick question on engine mounts for Honda Engine in my Monte Carlo i noticed the mounts at the
the bulk head had a small crack in the rubber so purchased ENERGY SUSPENSION Engine Mount Inserts to take up the play this insert was also fitted to the front mounting as well.
I then found the mount to the passanger side of the car was delaminating and needs replacing, from what i have found out I have to purchase a honda part 50805-s6m-j01 and then this is modified to fit the Z Car's mount, is this something we are able to do or does it have to be returned to Z Cars for them to mod.
Honda have told me its a  back back order so dont expect it till the end of August so no car for the lovely summer !!!!!!!!!
or is there another option.
Many thanks in advance
Don
#2 cptkirk
cptkirk
  • 1,799 posts
  • Local Club: B.M.C. + Chiminiclub
Posted 05 August 2015 - 10:47 AM
I didn't know the answer off the top of my head so I have had a look around on the tinternet to see if I can find an answer, seems the mount is altered considerably.
These are the OEM Mounts:
Honda%20K20%20OEM%20Engine%20Mounts_zpsd
As you will know - this is what the Zcars version looks like:
Zcars%20NS%20Engien%20Mount_zpsvxuubkqh.
I think if you can get the replacement part you could most probably press the rubber out and the press it into the Zcars outer mount......???
#3 dondo
dondo
  • 128 posts
Posted 05 August 2015 - 02:12 PM
That's the answer I was looking for  ''press out''.
Just the long weight for Honda.
#4 dondo
dondo
  • 128 posts
Posted 07 August 2015 - 03:35 PM
Mr Honda phoned to day to say the mount had arrived so job done and a wee shake down run.
Edited by dondo, 07 August 2015 - 03:41 PM.
#5 cptkirk
cptkirk
  • 1,799 posts
Posted 07 August 2015 - 03:40 PM
Mr Honda phoned to day to say the mounts had arrived so job done.
Excellent.
