mini r1 full time build
264 replies to this topic
#16 R1mini
R1mini
  • 1,386 posts
Posted 08 August 2006 - 06:46 PM
Just out of interest have you got a gap on the rear floor mounts?
David
do you mean in the centre on the floor or at the sides
This one
Can't add pictures for some reason, I will try again later
David
Edited by R1mini, 08 August 2006 - 06:49 PM.
#17 R1mini
R1mini
  • 1,386 posts
Posted 09 August 2006 - 09:35 AM
I'll try again
This Alloy spacer
I'm fed up now I'll work out it myself
Edited by R1mini, 09 August 2006 - 09:36 AM.
#18 koss
koss
  • 1,399 posts
  • Local Club: The Greenbank working mens social club
Posted 09 August 2006 - 11:17 AM
I'll try again
This Alloy spacer
:w00t: hi there you just have to click on reply then if you look down the page where file attatchment is
browse till you find your picture then ok then add this attachment it works for me
any way its nice to be back
Edited by koss, 09 August 2006 - 11:22 AM.
#19 R1minimagic
R1minimagic
  • 4,660 posts
Posted 09 August 2006 - 11:33 AM
David means do you have a gap between the floor mounts (5 point holes) and the floor. We both had subframes which had a 12mm gap when fitted!
Is that the engine you bought from me??!!
#20 koss
koss
  • 1,399 posts
Posted 09 August 2006 - 11:47 AM
it is mate decided to build full car
and you must be talking about the front subframe, what i did was leave the top bolts loose till i drilled the bottom and secured them first plenty of grease on the top ones and tighten them up
it would have had a 12mm gap with just the top secured
#21 R1mini
R1mini
  • 1,386 posts
Posted 09 August 2006 - 11:50 AM
Yeah I've added plenty of pictures in the past dead easy, but for some reason not working, I have tried this on three different computers now
David
Dale where are you today work or home?
#22 koss
koss
  • 1,399 posts
Posted 09 August 2006 - 11:53 AM
David
:w00t: guess what i cant upload pictures now
#23 markrally
markrally
    Z Cars
  • 1,378 posts
  • Local Club: Miniaddicts.co.uk
Posted 09 August 2006 - 12:08 PM
They have probably remove the picture uploader temporarily whilst they sort the virus problems as that is how it may have got into the server in the first place but im sure they will replace it when everything calm down,
In the meantime just host your photos on image shack or photobucket and paste the link into your posts.
Dead easy............
#24 koss
koss
  • 1,399 posts
Posted 09 August 2006 - 12:32 PM
[quote name='markrally73' post='331722' date='Aug 9 2006, 01:08 PM']
like this
Edited by koss, 09 August 2006 - 01:00 PM.
#25 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 09 August 2006 - 12:36 PM
http://i84.photobuck...headlining1.jpg
like this
No, You need to copy and paste the [img]Your picture code here[IMG/] code from photobucket and paste it in and then the pic will appear automatically
#26 koss
koss
  • 1,399 posts
Posted 09 August 2006 - 01:02 PM
:w00t: thanks mate
Edited by koss, 02 January 2007 - 03:19 PM.
#27 koss
koss
  • 1,399 posts
Posted 09 August 2006 - 03:25 PM
:w00t: now that i know how to post more pics heres an update most of the metal parts off the doner were plated niklechromate or something like that just finishes the job i think. i bought some alloy tubing and silicone hoses the silicone is very pricey so the elbows and long sections are made of alloy which i tig welded together you can buy these as a kit from zcars but this way ads to the fun of the buildPosted Image
Edited by koss, 02 January 2007 - 09:23 PM.
#28 koss
koss
  • 1,399 posts
Posted 09 August 2006 - 03:55 PM
More progress
Edited by koss, 02 January 2007 - 09:57 PM.
#29 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 09 August 2006 - 07:57 PM
What radiator are you using? The hoses are going to the wrong side ??? But i can accept correction as Chris may have changed the spec lately???
When is the monte due to be finished or is chris just doing the fabrication and your assembling it?
Whats your budget for each build if you dont mind me askin???
Edited by markrally73, 09 August 2006 - 07:59 PM.
#30 koss
koss
  • 1,399 posts
Posted 09 August 2006 - 09:04 PM
the radiator is the later one without the filler neck, supplied by chris i think its off a fiat or i know the sender for the fan is of a fiat i made my own header tank
way over original on budget dont ask and by the way do you do a bit of rallying my mate trevor gamble have you heard of him
