mini r1 full time build
264 replies to this topic
#151 markrally
markrally
    Z Cars
  • 1,378 posts
  • Local Club: Miniaddicts.co.uk
Posted 09 April 2007 - 09:51 PM
Mark
:P But you can take the big one out for track days. Mot and for sale end of April.
And the Monte????
#152 koss
koss
  • 1,399 posts
  • Local Club: The Greenbank working mens social club
Posted 09 April 2007 - 09:56 PM
Oh yes forgot about that. Must check up.
#153 koss
koss
  • 1,399 posts
Posted 29 April 2007 - 09:05 PM
Right had a bit of time this week and managed to do a little bit more. I am aiming to get this finished within the next two weeks.
Fitted some side repeaters as the indent looked daft in the sports pack arches without them.
Fitted some interior door handles so I can open the doors from the inside now. :closed:
Put some wire straps on the fibreglass front to stop it smashing the head lights.
Made a new front loom for the lights/indicators just to tidy things up. Also I must mention there is no left/right circuits for the lights, few ounces of copper saved there.
Still need to tidy wiring up for dash.
Fitted some eyeball vents to the dash and it still looks bare. Maybe it will look ok when I flock it.
I just get the feeling it needs something else.
I need some ideas on the bonnet badge. I have tried the cooper wings and they don't look right.
R1 badge held on with chewing gum for ideas. Maybe R1 at the side and a zcars logo of some sort in the middle ?
Well that's it for now but I still fancy one of them translogic power shifters :proud:
#154 koss
koss
  • 1,399 posts
Posted 09 May 2007 - 08:42 PM
A bit more to update on.
Bulkhead nearing finish, still need to tidy wiring up.
Rubber trims here and there.
Set about the fuel neck today and it turned out canny.
Oh and this flocking thing is harder than the instructions say >;)
Cheers for looking.
#155 JetBLICK
JetBLICK
  • 1,222 posts
  • Local Club: myspace.com/worcesterretro
Posted 09 May 2007 - 09:04 PM
oOoO good work. Is that the flocking from frost? can we have a little review of how easy it is to use and what the finish is like - any good? lol
#156 koss
koss
  • 1,399 posts
Posted 12 May 2007 - 05:59 AM
Steering wheel is near completion. Green are indicators, latching no relay required.
Blue is high beam also latching, requires a relay.
Red is the horn, momentary, requires a relay.
The cable is 15 core for any future mods. Yellow relays taken from the original loom.
The switches took a lot of finding being only 16mm long but they are ideal for this sort of application.
Everything is finished in heat shrink sleeving.
Edited by koss, 12 May 2007 - 06:02 AM.
#157 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 12 May 2007 - 06:39 AM
god that looks cool.
future mod for my next mini.
looks so good with no cowl and all that other gumpf
#158 JetBLICK
JetBLICK
  • 1,222 posts
Posted 12 May 2007 - 10:39 AM
Thats how i'm doin my wheel too, 'cept i've got a horn push on teh wheel, and i got another button for L/C
by the way how are you doing you're indicators? I'm doin mine like this... but i ran into a problem, cant find a normaly closed relay >_< any ideas?
#159 dean_chad
dean_chad
  • 733 posts
Posted 12 May 2007 - 01:48 PM
The relays on all the machines at work have 5 pin relays. the 2 solenoid pins then an option for n/o or nc from the remander of the 3 other pins, they should be availible anywhere buddy
#160 adyzr1
adyzr1
  • 257 posts
Posted 12 May 2007 - 07:59 PM
nice job ian!
#161 koss
koss
  • 1,399 posts
Posted 12 May 2007 - 11:28 PM
Thanks Ady, Interesting mod on your clutch.
JB. You are making things to complicated I fell in the same boat.
The 3 wires for the indicators that go to the stalk are very low amperage my switches are 0.25 watt rated.
To trigger the flasher relay you only need to apply a slight resistance not switched voltage, if you know what I mean.
Just put a meter across the green/white and green/brown to see how many amps.
While on the subject of electronics I have sorted the reverse with the engine still running thing.
Just wish I could do flocking >_<
#162 Poly_Patje
Poly_Patje
  • 82 posts
Posted 12 May 2007 - 11:37 PM
You are doing a outstandig job man! Those buttons and lights do like very nice on the steering wheel.
Keep up the good work.
ps: thnx for your reply. What about some kind of levers for gear switching >_<
#163 koss
koss
  • 1,399 posts
Posted 12 May 2007 - 11:49 PM
ps: thnx for your reply. What about some kind of levers for gear switching :strongsad:
Buttons and a solenoid I think or maybe a rev limiter with a output to change gear at max power and make it automatic. >_<
#164 Pie
Pie
  • 7,695 posts
  • Local Club: GoGoAuto
Posted 13 May 2007 - 01:24 AM
AMAZING!!!
Just read throught the entire thread tonight, and am amazed lol. Love the positon of the fuel filler cap, great thinking.
Think you should stick the R1 badge on the left of the bonnet (right when you face the bonnet, let when your driving it)
miniman-pie
#165 Racer_Pete
Racer_Pete
  • 2,492 posts
Posted 13 May 2007 - 06:35 PM
Pie you nicked what i was going to say >_< ! Brilliant build you have there. as pie sed to, love the way you have done the petrol tank to. pete
