mini r1 full time build
#136
Posted 15 January 2007 - 09:46 AM
I am hoping for a 50% reduction on noise as this is a road going car after all. Dont realy fancy me and the g/f sitting at the lights with a set of coms on. Done a 70 mile trip in the summer and me head was ringing with the noise. Ear plugs are no good either not when your listening for nuts and bolts comming loose and things falling off :'(
#137
Posted 28 January 2007 - 06:06 AM
The rear hood hooks on at the front and will be held down at the rear with bonnet pins.
The hood is easily removed for track days and side windows opened for some cool air.
#138
Posted 09 February 2007 - 11:29 PM
Decided the head lining looks absolutely dreadful so I changed it. It was also splattered with grease when I lost the grease nipple from the diff travelling at speed.
#139
Posted 09 February 2007 - 11:56 PM
#140
Posted 10 February 2007 - 12:10 AM
And there is loads more switches going on. Due to de stalking the column.
#141
Posted 10 February 2007 - 10:40 AM
My Hat Goes Off To You, Great Build. You Lucky Fu#ker
#142
Posted 10 February 2007 - 11:04 AM
#143
Posted 11 February 2007 - 12:01 AM
#144
Posted 12 March 2007 - 02:39 PM
could i have some info on the blue headlining and the heaters. Also what fastners are you using for the flip front?
Cheers,
Carl
#145
Posted 12 March 2007 - 10:48 PM
Fasteners on the side of the flip front are 6 x dzus onto the A panels. And the hinges are a top secret
Heaters are available from car builder solutions (like 12v hair dryers).
#146
Posted 15 March 2007 - 09:06 PM
phil.
#147
Posted 07 April 2007 - 07:54 PM
The sound proofing is absolutely amazing, I was hoping for a 50% reduction in noise and think I got more.
The only noise I get now seems to come from outside the car.
I also found time to look at the reverse staling problem, with a few surprises.
A large capacitor was fitted with + and - connectors. The cap is fed via a 6 amp diode from the +ve side of the battery (the diode being like a one way valve). So if the battery had a sudden voltage drop the cap would store 12 volts for a period of time.
The cap then supplies power to the ECU/ignition sys/injection sys.
After wiring every thing up I put it to the test. Set the idle @ 1800 revs to start with, hit the reverse and guess what? it stalled just like it did in the first place.
Out with the meter.
1 Test voltage on battery and note voltage drop when hitting reverse. Voltage drops down to 3 volts then rises to 9/10 within a second.
2 Test amps used by ecu/injection/ignition. Only 2 amps. Thought it would have been more.
3 Test voltage to ecu/injector sys/ignition while hitting reverse. Hey it stays 12v. So something works.
Going to wire the fuel pump to a separate battery tomorrow and see if the problem lies there.
Some pics off the mobile phone.
#148
Posted 09 April 2007 - 09:19 PM
Final decision I now have a motor bike battery running the engine and fuel pump. And a mini battery for reverse, lights etc and starting.
I can now do a 3 point turn without cutting the engine and it don't sound like a tram when the engines running.
Back on with the build.
#149
Posted 09 April 2007 - 09:40 PM
When is it going for mot?? and then for sale?
Any progress with the monte?
#150
Posted 09 April 2007 - 09:49 PM
