I own a Rover Mini Cooper S 1.3 1999
Grim times, but here goes ........
First of all a small bit of background to what my car has recently been through, poor thing! My car was reared recently by a clumsy french driver, caving in the boot and knocking the exhaust off its rubber mountings. Now the first thing I noticed was the shear difficulty of getting the exhaust back on to it mounting point so I thought maybe the shunt from the other vehicle had cause a slight bend in the exhaust somewhere. But, I don't know because thats the first interaction I have had with the exhaust, so could well be normal for my car (only purchased the car in February this year).
Anyway a few days prior to the accident I noticed a small pool of oil in my parking space, I had recently topped up after a long journey with 10w40 synthetic. I later read that 20w50 mineral would be the oil of choice for most rover mini owners. With that in mind I had to wait a month to get my car repaired (new boot and bumper), and drove to the nearest place to buy oil. Now then, the car ran fine with no issues but was low on oil (10w40). I purchased 20w50 and put 5L of the stuff in.
This is where the problems start, when driving under say 3000rpm its ok, but anything above that my exhaust chucks out a mass amount of white smoke as though my car has decided it wants to take up making clouds as a hobby! I drove it for around 15miles at about 35mph and the smoke was no existant, then when I put my foot down and went above the 3000rpm I got the mass amount of smoke again .... not good at all !!
I am a novice when it comes to cars, but I was thinking surely the piston rings or seals wouldnt just go instantly and would be more of a wearing process gradually getting worse? Or is the mix of oil causing the issue because I didnt drain the 10w40 initially before putting the 20w50 in? Is the 20w50 too thick for my car?
Any help would be appreciated, I think my first port of call is to drain the oil and put the 10w40 back in to see if the problem persists. But the car does have an oil leak and it drops down from the front of the engine.
thanks in advance, sorry for the lack of technical explanation!
Pete
Edited by peteygee, 29 July 2015 - 08:22 AM.
