1971 Mini Van South African Import
87 replies to this topic
#76 BronkoMini
BronkoMini
  • 1,484 posts
  • Local Club: Mini Fixers
Posted 17 April 2019 - 10:54 PM
And it starts. The squeaking is from the belt as water is leaking out the thermostat housing bolts. Also the fuel pressure gauge isn’t picking up any pressure for some reason:
https://youtu.be/Ju6qSz003m8
#77 BronkoMini
BronkoMini
  • 1,484 posts
Posted 18 April 2019 - 10:41 AM
#78 BronkoMini
BronkoMini
  • 1,484 posts
Posted 26 April 2019 - 05:30 PM
Sooo rolling road done, there was so much fiddling around with needles etc, but eventually it was sorted, we discovered the temp gauge doesnt work and to get the correct fuel pressure the screww has to be wound fully in so the locking nut cant be put on. Also discovered a little fuel leak.
Anyway, we've set the boost to 6psi to be safe as we want the car to make it to L2B, when it was set at 6.8psi it got 110 bhp, but reducing got us to a safe 98bhp and 112Ibs/ft
Pictures and a video to follow.
#79 nev100
nev100
  • Just Joined
  • 143 posts
Posted 26 April 2019 - 06:08 PM
Brilliant lads. Well done
It's been a great effort.
Can't wait to see the videos and it running for real....
#80 BronkoMini
BronkoMini
  • 1,484 posts
Posted 26 April 2019 - 08:22 PM
#81 BronkoMini
BronkoMini
  • 1,484 posts
Posted 26 April 2019 - 08:24 PM
46791434485_931b4aef7f_z.jpgUntitled by Bryn Kinsman, on Flickr
32764249317_e632e65e7b_z.jpgUntitled by Bryn Kinsman, on Flickr
32764249007_d48c92e11e_z.jpgUntitled by Bryn Kinsman, on Flickr
#82 BronkoMini
BronkoMini
  • 1,484 posts
Posted 19 May 2019 - 09:09 PM
So long time no post:
We managed to bleed the brakes etc.
Took it top Himley hall for a shakedown for London to Brighton. That went horribly wrong, on the way there the oil pressure guage pipe started to leak, spraying oil all over the engine, so we had to buy a new one there:
46967542565_2138ae27cc_z.jpgUntitled by Bryn Kinsman, on Flickr
The engine breathed heavily and smoked alot so we thought the rings must be dodgy as the engine had been sat a while, it then started to smoke more, this time white smoke and it over heated, boiled over, water all came out the turbo water return.
We came to the conclusion the head gasket had gone. Also it was dangerous as the steering rack was awful so was a hand full. So we decided to take the engine out the Monday before L2B, so we had better access:
47883645021_0b6fc7b03d_z.jpgUntitled by Bryn Kinsman, on Flickr
Took the head off:
40917176543_c677f5c48d_z.jpgUntitled by Bryn Kinsman, on Flickr
Only to discover the cause of the smoking and heavy breathing:
47831723442_5f199f72db_z.jpgUntitled by Bryn Kinsman, on Flickr
We needed the car back on the road for L2B so put on a new gasket and assembled it all.
We then changed the rack:
47831700232_fea916043c_z.jpgUntitled by Bryn Kinsman, on Flickr
Next we decided to change the wheel baring as it wasnt the best, the old race got stuck in the hub so we bought a new one, ended up having to get a new drive shaft, 2 new inner pot joints and a outer cv:
46967533675_9ac62c7c88_z.jpgUntitled by Bryn Kinsman, on Flickr
46967536195_04b975b2c1_z.jpgUntitled by Bryn Kinsman, on Flickr
Safety first haha:
47831696412_0045ffe568_z.jpgUntitled by Bryn Kinsman, on Flickr
We got it all back in on Saturday, took it for a test drive, re torqued the head and washed it ready for L2B:
46967561145_116f2a7cf6_z.jpgUntitled by Bryn Kinsman, on Flickr
Made it to Crystal palace, but the water temp guage stopped working, we think this happened as my brother managed to make the oil pressure braided tube live which melted a lot of stuff and damaged the water capillary tube, that meant changing of the oil pipe and some other stuff on the Saturday. Its scary driving without a temp gauge:
Any way we made it to Brighton quite late as we lost the clutch, the lock nut on the adjuster came loose and caused it to wind in, we found out what was wrong thanks to the help of a kind man. We didnt have the right size spanner so we had to call the AA, the AA man had a K series mini which was cool. He also had to bleed the clutch again as it got air in when i was fiddling with it:
47831725732_de013c937e_z.jpgUntitled by Bryn Kinsman, on Flickr
We eventually made it to Brighton. And then home now without any other issues other than what i think is the actuator sticking open so no boost was produced occasionally:
47831714292_1a5e61d025_z.jpgUntitled by Bryn Kinsman, on Flickr
47883633471_5724485ec9_z.jpgUntitled by Bryn Kinsman, on Flickr
47883624791_184cb7c000_z.jpgUntitled by Bryn Kinsman, on Flickr
47831714012_136eee32a7_z.jpgUntitled by Bryn Kinsman, on Flickr
Not sure if that made any sense haha
#83 BronkoMini
BronkoMini
  • 1,484 posts
Posted 21 May 2019 - 05:03 PM
Little video from L2B:
https://youtu.be/HRLzonshJJs
#84 BronkoMini
BronkoMini
  • 1,484 posts
Posted 21 May 2019 - 05:04 PM
#85 BronkoMini
BronkoMini
  • 1,484 posts
Posted 09 December 2019 - 03:03 PM
Long time no post.
Built up the gearbox:
49193172768_36a364f156_z.jpgUntitled by Bryn Kinsman, on Flickr
The specialist Components sump pug magnet is so much stronger than the normal one:
49193870522_8338f4755d_z.jpgUntitled by Bryn Kinsman, on Flickr
Three different levels of diff:
49193675091_339d6847e3_z.jpgUntitled by Bryn Kinsman, on Flickr
Engine all built up:
49188552722_3e68b8de8e_z.jpgUntitled by Bryn Kinsman, on Flickr
Spent way too much money on bling:
49188551622_ca77cab98f_z.jpgUntitled by Bryn Kinsman, on Flickr
49188357356_613f2658c7_z.jpgUntitled by Bryn Kinsman, on Flickr
Started tipping it when we were putting the engine in, quickly the gazebo was put up:
49187855288_ccdee78e3a_z.jpgUntitled by Bryn Kinsman, on Flickr
Engine in, passenger driveshalf wont fully go into the pot joint for some reason:
49193712921_247e994fa7_z.jpgUntitled by Bryn Kinsman, on Flickr
49193208318_0f8f90f332_z.jpgUntitled by Bryn Kinsman, on Flickr
Edited by BronkoMini, 09 December 2019 - 03:05 PM.
#86 BronkoMini
BronkoMini
  • 1,484 posts
Posted 10 April 2020 - 07:17 PM
So i've been away working in New Zealand, ended up getting stuck there, had two flights cancelled, probably wont be getting my money back for them then finally got on the third flight two weeks later, which was an extortionate price, but got me home, so that's loads of my mini fund gone.
49757908726_7845bc696e_z.jpgUntitled by Bryn Kinsman, on Flickr
Anyway got back, didn't even get a change to unpack, sorted out the drive shafts, some piping and some other random bits, got it started, bedded in the cam, then took it for a test drive, up a private road i must add, to check we'd assembled the gear box etc properly, now just got to wait for the end on the lock down to go get it set up properly.
49758211907_0101bea6ba_z.jpgUntitled by Bryn Kinsman, on Flickr
#87 BronkoMini
BronkoMini
  • 1,484 posts
Posted 16 April 2020 - 07:21 PM
Tried out the KAD quick shift, takes some getting used to:
#88 BronkoMini
BronkoMini
  • 1,484 posts
Posted 31 May 2020 - 08:21 PM
Little camera test and DSN towing eye gopro mount test as we check the car is ready for the rolling road
