1971 Mini Van South African Import
87 replies to this topic
#61 do_arte
do_arte
    Starting My Mini Up
  • 1 posts
Posted 12 March 2017 - 10:49 PM
This is my MINI Van! the portuguese MINI IMA only with one rear door :)
Edited by do_arte, 12 March 2017 - 10:50 PM.
#62 BronkoMini
BronkoMini
  • 1,484 posts
  • Local Club: Mini Fixers
Posted 26 January 2018 - 05:54 PM
Been a bit busy with work recently, but the van decided it didnt like its gear box on christmas eve. Just got round to splitting the engine and this is what i found.
#63 BronkoMini
BronkoMini
  • 1,484 posts
Posted 25 November 2018 - 01:28 PM
So not updated this for a while!
Been pretty busy with work but now silly season is over i have time to sort this out.
I've actually done quite a lot to this.
So I was doing a metro turbo conversion on my saloon, but chose to go 16v instead, so that freed up the metro turbo for this.
Its a Metro turbo, 1310, GT1752 turbo, fusion fabrication manifold, mega jolt ignition, that's the basic spec, hope to have it running before christmas so i can sort my mini out before summer!
This is how the engine sits now:
46040924441_84141d5e2a_z.jpgUntitled by Bryn Kinsman, on Flickr
 So a to do list, with things off the top of my head:
Modify turbo so i can put the 4th manifold stud and nut on, already drilled out the turbo threads, just need to grind.
Rotate turbo and make a bracket to relocate the actuator.
Find a place to put the fuel pressure regulator, then plumb in fuel return.
Fit trigger wheel and sensor.
Put radiator and other cooling system parts on, and paint some of them.
Buy some adjustable engine steadies.
Buy a lambda sensor and gauge.
Still looking for a throttle linkage for this.
Dont think theres much more before we can put the engine in. My biggest worry is sorting out the megajolt
Edited by BronkoMini, 25 November 2018 - 05:45 PM.
#64 BronkoMini
BronkoMini
  • 1,484 posts
Posted 25 November 2018 - 01:29 PM
This is my thread over on turbo mins, its got a bit more detail in:
http://www.turbomini...id=580759&fr=50
#65 BronkoMini
BronkoMini
  • 1,484 posts
Posted 25 November 2018 - 04:36 PM
And yes the engine has been painted pink  :lol:
#66 nev100
nev100
  • Just Joined
  • 143 posts
Posted 25 November 2018 - 05:29 PM
Get it done for the club Xmas do, Bryn !!
That's 3 weeks, I think...
Neil.
#67 nev100
nev100
  • Just Joined
  • 143 posts
Posted 25 November 2018 - 05:31 PM
Neil.
#68 BronkoMini
BronkoMini
  • 1,484 posts
Posted 25 November 2018 - 05:42 PM
Neil.
Haha I shall try, will see how it goes.
Bryn
#69 nev100
nev100
  • Just Joined
  • 143 posts
Posted 25 November 2018 - 07:35 PM
You've got a useful helper/brother
#70 BronkoMini
BronkoMini
  • 1,484 posts
Posted 25 November 2018 - 07:47 PM
I think you mean i have a brother, he's neither useful or a helper  :lol:
#71 BronkoMini
BronkoMini
  • 1,484 posts
Posted 20 March 2019 - 06:55 PM
Small update:
The engine has been in a while, there's not too much more to do, but as everyone knows random jobs come out of nowhere.
This is what it looks like currently:
46513899285_b629291b4d_z.jpgUntitled by Bryn Kinsman, on Flickr
#72 BronkoMini
BronkoMini
  • 1,484 posts
Posted 20 March 2019 - 07:05 PM
Some random pics of whats happened:
Oil drain:
46445545814_8786014c66_z.jpgUntitled by Bryn Kinsman, on Flickr
32236948497_324fb08d64_z.jpg by Bryn Kinsman, on Flickr
Actuator re positioning mount:
40213897283_4bfe1a8b0b_z.jpg by Bryn Kinsman, on Flickr
40213897743_3d58f4358d_z.jpg by Bryn Kinsman, on Flickr
Fuel pump:
47178682761_3a3cf85b0c_z.jpg by Bryn Kinsman, on Flickr
Inter cooler location idea:
46296126455_4ec46a113d_z.jpg by Bryn Kinsman, on Flickr
Had to change the brake end of the drive shaft:
46304346425_0752e424d3_z.jpg by Bryn Kinsman, on Flickr
Need a 90 degree fitting for the water drain:
47369208131_02378b680b_z.jpg by Bryn Kinsman, on Flickr
Changed the brakes. Need to fit the mini fins on the rear before bleeding the brakes:
47369209861_22f9a02f99_z.jpg by Bryn Kinsman, on Flickr
Oil catch can:
47369210611_e8335216d2_z.jpg by Bryn Kinsman, on Flickr
Currently trying to change from intertia to pre engaged starter motor, any help would be greatly recieved, ive put both the battery input and cable to the starter motor on the same terminal:
47376160482_0555fd355f_z.jpg by Bryn Kinsman, on Flickr
Sorting out the megajolt wiring:
33553056998_226e09df43_z.jpg by Bryn Kinsman, on Flickr
#73 BronkoMini
BronkoMini
  • 1,484 posts
Posted 17 April 2019 - 10:39 AM
Nearly there, just need to sort out the wiring, get an air filter, fill up with fluids, put the engine earth on and HT leads and spark plugs, then we can have a look at getting it started:
46898946784_7ea8a7994a_z.jpgUntitled by Bryn Kinsman, on Flickr
46898945254_09a8aed985_z.jpgUntitled by Bryn Kinsman, on Flickr
#74 BronkoMini
BronkoMini
  • 1,484 posts
Posted 17 April 2019 - 10:40 AM
Edis etc located:
40642357973_4acdf31fec_z.jpgUntitled by Bryn Kinsman, on Flickr
Exhaust modified and fitted:
40642358393_e56ce1233b_z.jpgUntitled by Bryn Kinsman, on Flickr
46884672674_3d2b247868_z.jpgUntitled by Bryn Kinsman, on Flickr
46693249435_25ebc32517_z.jpgUntitled by Bryn Kinsman, on Flickr
46884673694_485e4dde0b_z.jpgUntitled by Bryn Kinsman, on Flickr
Fuel pressure regulator bracket made up:
47615921301_5b3e004a82_z.jpgUntitled by Bryn Kinsman, on Flickr
47615920821_0e1dd2f48b_z.jpgUntitled by Bryn Kinsman, on Flickr
And fitted:
47623210811_e352155ffe_z.jpgUntitled by Bryn Kinsman, on Flickr
Radiator top bracket made and fitted:
32673327177_f16eda4ed3_z.jpgUntitled by Bryn Kinsman, on Flickr
Rear brakes changed, just need bleeding:
32673327497_e1f069e9f2_z.jpgUntitled by Bryn Kinsman, on Flickr
32673327417_75a4496539_z.jpgUntitled by Bryn Kinsman, on Flickr
Boost controller plumbed in just need wiring in:
47623212201_75555da10b_z.jpgUntitled by Bryn Kinsman, on Flickr
Fuel pressure gauge fitted inline:
47623212441_53ac509892_z.jpgUntitled by Bryn Kinsman, on Flickr
#75 nev100
nev100
  • Just Joined
  • 143 posts
Posted 17 April 2019 - 12:29 PM
About bloody time.....!! Ha ha...
Great effort lads. Looking forward to seeing and hearing it.
