Gearbox / Exhaust Bracket Help!
12 replies to this topic
#1 monkey
monkey
  • 1,382 posts
  • Local Club: Diss Mini Club
Posted 26 July 2015 - 09:44 AM
hiya, so recently brought Betty and her exhaust has been blowing at the manifold clamp, brought some exhaust paste, took the bracket off, went to loosen the gearbox bracket, only to find it doesn't exist :-/
So in the picture below you can see the bracket is on the exhaust but there is no where to bolt it too
Presumably I need one of these...
https://m.minispares...ni~shop/GEX7526
But wondering if / when I bolt it to the gearbox am I going to loose oil out of the box? Looks like I will have to undo the diff housing(?) bolts?
Also, what size bolt am I going to need to bolt the gearbox bracket to the exhaust bracket?
Sorry for the long post and thanks for the help! :-)
#2 monkey
monkey
  • 1,382 posts
Posted 26 July 2015 - 09:45 AM
Or is this the one I need?
https://m.minispares...ni~shop/GEX7088
Should add it a '87 998, standard exhaust :-)
#3 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 26 July 2015 - 10:01 AM
Id buy the 2nd one as its cheaper lol
#4 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 26 July 2015 - 10:30 AM
The first one is the one you want. You shouldn't lose any oil. Ideally you'll need two slightly longer 5/16 UNC bolts, perhaps an inch or 1 1/4" long. The original ones may be ok but be careful not to overtighten them.
#5 monkey
monkey
  • 1,382 posts
Posted 26 July 2015 - 03:31 PM
Thanks for the replys, will order the bracket next weekend (waiting for pay day) :-)
Also, what sort of nut and bolt will I need to hold the exhaust bracket to the gearbox bracket? Unfortunately I don't have any spare nuts/bolts in the garage :-(
#6 Icey
Icey
  • 1,551 posts
Posted 26 July 2015 - 04:02 PM
Before bolting anything more into that area why not deal with the failed selector seal? You'll only be taking it all off again to sort it anyway....
#7 monkey
monkey
  • 1,382 posts
Posted 26 July 2015 - 05:09 PM
Haha was hoping no one would notice that :-P is it an easy job? how do you remove the old seal?
#8 Icey
Icey
  • 1,551 posts
Posted 26 July 2015 - 09:07 PM
It's not too bad. If you don't have the aluminium ring in there it's a hour or so to do (you have to drain the oil). If the ring is in there it's more awkward as it can be tricky to get out; I had to drill the one in ours to get a grip on it with some pliers not helped by a glob of sealer put in at the factory (which was also a pain to clean out). It's more awkward than difficult.
Unfortunately it didn't completely solve the leak on ours as the outer end of the shaft had been scuffed so the oil seal doesn't seal completely.
#9 mk1leg
mk1leg
  • 9,343 posts
Posted 26 July 2015 - 09:28 PM
you can just see the bracket in this pic.......
#10 Dusky
Dusky
  • 5,322 posts
Posted 27 July 2015 - 06:04 AM
I never drain the oil to change the selector seal, even without the alloy ring
#11 monkey
monkey
  • 1,382 posts
Posted 27 July 2015 - 08:56 AM
Well in that case I will add a seal to the ever growing list! :-P
Thanks for the picture mk1 - all makes sense now! :-)
Whilst I have it up on the ramps I was gonna change the rear subframe mounts as well as one is knackered, firstly any tips for this job, and secondly, what's the difference (apart from massive price difference) between the two products below...
https://m.minispares...~shop/21A2599MS
https://m.minispares...ni~shop/21A2599
Thanks again in advance, gonna be a big order at the weekend! :-P
#12 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 28 July 2015 - 06:41 AM
The Minispares own brand are fine.
#13 monkey
monkey
  • 1,382 posts
Posted 28 July 2015 - 09:48 AM
Ty John, was hoping that was the case considering the price difference!
