Best Etch Primer
27 replies to this topic
#1 cookie4343
cookie4343
    **Caution: Do Not Feed Alcohol**
  • 2,257 posts
  • Local Club: CV1 Mini's
Posted 25 July 2015 - 07:25 PM
So I've been having a few problem, I took my mini down to bare metal and etch primed it with autotek etch primer shown here http://www.ebay.co.u...=item3f4009cc3a
Anyway its basically crap every time I stick masking tape near it it just peels off, can anyone recommend me a decent etch primer that they have used/tested.
I'll be sanding it back off before applying new.
Edited by cookie4343, 25 July 2015 - 07:26 PM.
#2 Harrison541
Harrison541
    A bowl of prawns, avocado and cress?
  • 498 posts
Posted 25 July 2015 - 07:40 PM
I've got some of their black paint and its a bit crap really, Upol etch primer is quite highly regarded, I know someone in the trade who uses it.
#3 cookie4343
cookie4343
  • 2,257 posts
Posted 25 July 2015 - 07:52 PM
I was thinking of just using acid 8, there aerosols are £12.99 or a litre to go though the gun at £28 not sure if 2 aerosols would go further or the 1lt in the gun.
#4 cookie4343
cookie4343
  • 2,257 posts
Posted 25 July 2015 - 07:54 PM
I've scuffed the bare metal with 180 grit and still peels, degreased etc, the metal does end up quite shiny after scuffing, not sure if the shiny steel is the cause.
Edited by cookie4343, 25 July 2015 - 07:55 PM.
#5 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 July 2015 - 07:59 PM
It shouldn't be. It just sounds like a poor primer to me.
The zinc primer i use goes straight onto quite polished metal that's been cleaned with a filament brush and adheres fine.
I would try again with a better quality etch
#6 cookie4343
cookie4343
  • 2,257 posts
Posted 25 July 2015 - 08:06 PM
Cheers Ben think I'll just buy some acid 8, expensive but needs must as the topcoat depends on it.
#7 cookie4343
cookie4343
  • 2,257 posts
Posted 25 July 2015 - 08:11 PM
Anyone used this before made by e-tech http://www.ebay.co.u...=STRK:MEBIDX:IT
I've used e-tech lens tint before and it went on well.
#8 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 25 July 2015 - 08:23 PM
MIPA do a nice high build etch primer, not had any trouble with that, covers nice and sticks well.
#9 cookie4343
cookie4343
  • 2,257 posts
Posted 25 July 2015 - 08:29 PM
This one shifty http://www.ebay.co.u...=item2c9de7872f
Do you reckon the aerosols are just as good as there more convenient http://www.ebay.co.u...=item35ed2c5dbc
Edited by cookie4343, 25 July 2015 - 08:32 PM.
#10 Shifty
Shifty
  • 13,138 posts
  • Name: Sean
Posted 25 July 2015 - 08:39 PM
That's the one, both are pretty good, the non aerosol  one needs 2k thinners though.  I've used both of them and they've been great, you can brush on the tin one as well!!
#11 cookie4343
cookie4343
  • 2,257 posts
Posted 25 July 2015 - 08:40 PM
Cheers shifty think I'll give It a try got to be better than the autotek crap.
#12 deepee71
deepee71
  • 101 posts
Posted 26 July 2015 - 05:38 AM
Try ProXL, in my opinion way better than Upol acid etch 8. It comes with a way better nozzle than the crappy effort you get with the Upol stuff.
Andy
#13 Daz1968
Daz1968
  • 2,058 posts
Posted 26 July 2015 - 08:09 AM
Also don't forget etch primer is used to give a grip for next coat it shouldn't be left any length of time without over coating.
#14 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 26 July 2015 - 09:30 AM
Never had any problems with the Autotek etch primer.
Used it on mild steel and fibreglass, sand, degrease and then a light dust coat followed by a slightly thicker coat.
Had issues with UPOL etch primer in the past but I think that's down to be applying a too thicker coat, using light dust coats with no issues.
How thick are the coats you're applying?
http://www.mig-weldi...o.uk/primer.htm
Ian
#15 cookie4343
cookie4343
  • 2,257 posts
Posted 26 July 2015 - 02:52 PM
Ian
Just enough to cover the steel then normal primer on top.
As soon as I put masking tape on it it peels maybe I'm doing something wrong but never really had this type of problem before.
