Rear Fog Lamp
Posted 23 July 2015 - 12:03 PM
Posted 23 July 2015 - 12:43 PM
I think the fuse for the fog is one of the inline ones underneath the scuttle (however I could be wrong!), what age is your mini? The reason I ask is my clubman is 1973 so I've been told by a local test centre (fussy as well) that it'll only get a test that was typical of its age, ie; it gets started and as long as there is no blue/white/heavy reek coming out the exhaust then that'll be fine. So I've always wondered if an eighties or nineties mini will have the same type of test relative to it's age? You could always sort the headlight and fog yourself then book into a test centre that's a good distance away and give her beans on the drive there to clear her out!!
Edited by skoughi, 23 July 2015 - 12:51 PM.
Posted 23 July 2015 - 12:51 PM
Has the old MOT actually run out as it is still in effect even if you fail the new test?
You can use the car to go to an MOT test IF you pre-book it. Take the car for an "Italian Tune-Up" on the way there ... gets the catalytic converter heated up.
Or take it somewhere else that's (a) further away to get heat into the engine/exhaust and (b) are more forgiving of Classic cars.
Posted 23 July 2015 - 02:36 PM
Posted 23 July 2015 - 02:44 PM
I had the rear fog/interior light problem on mine.... (1991 Cooper Carb)
It did turn out to be the inline fuse under the bonnet (under the scuttle) the wiring was frayed aswel... Have ended up putting a spade fuce box in place of the inline fuses which has sorted it right out :)
Edited by Zara, 23 July 2015 - 02:44 PM.
Posted 23 July 2015 - 05:50 PM
£60 at general labour rates is an hour or two, which is probably what it'll take to sort out any electrical issues and the emissions, so to be honest, pay the £60, get your MOT and job done...
If you feel like you've been had over, then just don't go there again...
Posted 23 July 2015 - 07:25 PM
Posted 23 July 2015 - 07:34 PM
Posted 24 July 2015 - 08:35 AM
Posted 24 July 2015 - 08:39 AM
Posted 11 September 2015 - 05:41 PM
I have had the same issue with mine and tried fixing it in the same way, with a blade type box still no fog light though. Any other ideas? Cheers.
Posted 13 September 2015 - 07:48 AM
Just for info, here in Norway, £60 would get you about 30 minutes of a mechanic's time.
