1989 Mayfair Project
44 replies to this topic
#31 johnR
johnR
  • 2,292 posts
Posted 21 August 2022 - 02:21 PM
coming on, what's your plan for engine and final look?
#32 Mito
Mito
  • 408 posts
Posted 21 August 2022 - 03:42 PM
I've got a 1275 a series engine to go in which I'll rebuild and tune but not sure exactly what yet.
I'm going to keep the same blue and probably a metallic black roof and bonnet stripes.
#33 Mito
Mito
  • 408 posts
Posted 13 August 2023 - 06:50 PM
3 weeks after my last post we had to move house (buyer getting antsy).
The shell is currently in my parents garage, due to us having to move in to temporary accommodation for 6 months, and should be being picked up in a few weeks time.
In the meantime I've been collecting the remaining panels, decided to put heritage panels on the frontend rather than the aftermarket panels I had originally bought for it.
Attached File  PXL_20230801_174217599.jpeg   85.54K   2 downloads
Attached File  PXL_20230801_174221193.jpeg   79.24K   1 downloads
Also bought some of the parts for refurbing the rear arms and also the tool to fit the new bushes.
Attached File  PXL_20230801_174308066.jpeg   56.42K   1 downloads
Attached File  PXL_20230801_174258946.jpeg   66.8K   1 downloads
Picked up a parts washer and shot blasting cabinet
Attached File  IMG-20230812-WA0003.jpeg   25.47K   2 downloads
And started to strip down one of the rear arms, just inner bearing race proving a pita to remove. Gave it a bit of a clean up in the shot blasting cabinet as well - it needs more before painting.
Attached File  PXL_20230812_162027538.jpeg   103.61K   2 downloads
more parts awaiting refurb
Attached File  PXL_20230812_162036110.jpeg   94.54K   2 downloads
Attached File  PXL_20230812_162056070.jpeg   77.38K   2 downloads
#34 Mito
Mito
  • 408 posts
Posted 09 October 2023 - 03:32 PM
Today the mini was moved to it's new home.
Ready for loading
Attached File  1000040635.jpg   65.01K   1 downloads
Loaded up
Attached File  1000040637.jpg   107.42K   2 downloads
On the road
Attached File  1000040640.jpg   91.84K   2 downloads
Arrived at it's new home
Attached File  1000040643.jpg   82.43K   4 downloads
In the garage
Attached File  1000040645.jpg   79.16K   6 downloads
#35 Mito
Mito
  • 408 posts
Posted 19 November 2023 - 09:22 AM
Only had chance to do a little bit on it this weekend but at least it's a start.
Fabricated and welded on a repair piece for the top of the inner wing.
Attached File  1000041276.jpg   76.71K   5 downloads
Cut off the bulk of the skittle.
Attached File  1000041278.jpg   91.83K   3 downloads
Attached File  1000041279.jpg   69.04K   2 downloads
Attached File  1000041282.jpg   40.57K   2 downloads
Originally I was going to leave the skuttle on but seeing what's underneath and the poor repair to one of the corners and the closing plates, I'm glad I've cut it off.
Next up well be removing the remnants of the skuttle and then cleaning it all up. I also need to make a repair to the passenger side inner wing around the fresh air vent hole. It has a plate welded around it covering some corrosion.
#36 Viktor
Viktor
  • 653 posts
Posted 19 November 2023 - 07:30 PM
Good decision about the scuttle, the closing panels get very rusted and all around them... Doing mine now...
Victor.
#37 Mito
Mito
  • 408 posts
Posted 26 November 2023 - 05:44 PM
Today's job was cutting away the remaining pieces of scuttle and the rusty part of the flitch panel
Scuttle cut away
Attached File  1000041389.jpg   91.94K   0 downloads
Put a bit of primer on.
Attached File  1000041390.jpg   74.26K   1 downloads
Attached File  1000041387.jpg   71.5K   2 downloads
Flitch cut out.
Attached File  1000041388.jpg   74.4K   1 downloads
#38 Mito
Mito
  • 408 posts
Posted 28 March 2024 - 06:47 PM
Removed the paint from inside the a pillar and treated it with deox gel
Attached File  PXL_20240327_121427957.jpeg   43.03K   1 downloads
Attached File  PXL_20240327_121435087.jpeg   45.77K   0 downloads
Attached File  PXL_20240327_121432557.jpeg   40.72K   1 downloads
Then applied some hydrate 80 and over painted with epoxy mastic primer.
Attached File  PXL_20240328_174132600.jpeg   42.86K   0 downloads
Attached File  PXL_20240328_174136322.jpeg   47.15K   0 downloads
Then got to work stripping the paint of the bulk head
Attached File  PXL_20240328_174200415.jpeg   87.42K   0 downloads
The plan for the bulk head is to strip the paint off to ensure there's no rust lurking under the old paint, then cover with deox gel to remove any rust before the new scuttle is put on and the front end.
#39 Mito
Mito
  • 408 posts
Posted 08 April 2024 - 10:58 AM
The next job was to start repairing the flitch. I cut out the part from a glitch repair panel and welded it in.
Attached File  1000044260.jpg   34.6K   2 downloads
Attached File  1000044261.jpg   60.68K   2 downloads
Attached File  1000044360.jpg   41.68K   1 downloads
There are another couple of pieces that I'll need to fabricate.
Next, I started cleaning up the top half of the bulkhead.
Attached File  1000044262.jpg   82.53K   1 downloads
Attached File  1000044358.jpg   87.11K   0 downloads
Attached File  1000044359.jpg   68.18K   0 downloads
Then I applied some detox gel and left overnight.
Attached File  1000044373.jpg   52.38K   0 downloads
Attached File  1000044371.jpg   109.8K   0 downloads
#40 Mito
Mito
  • 408 posts
Posted 08 April 2024 - 03:43 PM
Today I fabricated a couple of pieces to complete the flitch repair and welded them in.
Attached File  1000044393.jpg   40.35K   2 downloads
#41 Mito
Mito
  • 408 posts
Posted 06 May 2024 - 05:38 PM
The Deox gel was left on for over 48 hours before it was cleaned off.
Attached File  PXL_20240414_145030888.jpeg   70.23K   0 downloads
Attached File  PXL_20240414_145027465.jpeg   64.85K   0 downloads
Attached File  PXL_20240414_145020737.jpeg   85.93K   0 downloads
Attached File  PXL_20240414_123842949.jpeg   81.7K   0 downloads
Attached File  PXL_20240414_123835958.jpeg   67.46K   0 downloads
Overall the results were good but there was still a bit of rust left on the left side, so I applied some more deox gel for a couple of hours to try to get the remainder.
Attached File  PXL_20240414_145038400.jpeg   63.08K   0 downloads
After this I prepped it for some epoxy primer.
Attached File  PXL_20240420_162730196.jpeg   52.51K   0 downloads
Attached File  PXL_20240420_180335049.jpeg   74.75K   0 downloads
Attached File  PXL_20240420_162723019.jpeg   74.93K   0 downloads
Attached File  PXL_20240420_162713683.jpeg   48.5K   0 downloads
Attached File  PXL_20240420_162708938.jpeg   39.47K   0 downloads
I did get a few runs in it but shouldn't matter as it will be flatted back before top coating and this is more just to prevent it from rusting.
#42 Mito
Mito
  • 408 posts
Posted 17 May 2024 - 10:15 PM
This week the scuttle has been welded and the two closing plates
Attached File  1000045102.jpg   84.12K   0 downloads
Then the wings and front panel were clamped back on ready for welding.
Attached File  1000045101.jpg   85.49K   0 downloads
Attached File  1000045103.jpg   83.91K   1 downloads
Attached File  1000045111.jpg   42.47K   1 downloads
Attached File  1000045104.jpg   82.82K   2 downloads
Attached File  1000045105.jpg   43.93K   2 downloads
Attached File  1000045106.jpg   43.14K   2 downloads
Attached File  1000045109.jpg   38.85K   2 downloads
Attached File  1000045108.jpg   74.4K   3 downloads
Attached File  1000045107.jpg   41.68K   3 downloads
Attached File  1000045110.jpg   73.9K   3 downloads
On the whole it has lined up quite well. The only real issue at the moment is the gap between the wing and bonnet increases to from the width of a £2 coin to the width of 2 £2 coins as it goes back towards the scuttle. Both wins are against the edge of the inner wing, so there's no way of moving them further in.
#43 Mito
Mito
  • 408 posts
Posted 10 July 2024 - 08:36 PM
The front-end is now welded on. No turning back now :).
Attached File  1000045248.jpg   75.99K   1 downloads
Attached File  1000045250.jpg   41.18K   0 downloads
Attached File  1000045249.jpg   41.34K   0 downloads
Attached File  1000045259.jpg   32.73K   0 downloads
Attached File  1000045258.jpg   43.76K   0 downloads
Attached File  1000045252.jpg   34.86K   0 downloads
Attached File  1000045251.jpg   39.14K   0 downloads
Attached File  1000045254.jpg   77.37K   0 downloads
Attached File  1000045255.jpg   78.97K   0 downloads
Attached File  1000045257.jpg   38.91K   0 downloads
Attached File  1000045253.jpg   36.5K   0 downloads
This week, I'm focusing on grinding the welds back and tidying them up.
So far I've completed the o/s a panel seam and the two sides of the wings.
Attached File  1000045849.jpg   47.03K   1 downloads
Attached File  1000046007.jpg   45.21K   1 downloads
Attached File  1000046008.jpg   42.8K   0 downloads
#44 lsto
lsto
  • 580 posts
Posted 10 July 2024 - 11:00 PM
Nice to see you making progress on this, it's beginning to look like a car again, keep up the good work.
#45 Mito
Mito
  • 408 posts
Posted 25 August 2024 - 09:34 AM
I've ground back most of the welds on the frontend now; missed the ones under the drivers side front panel lip though, so still have to grind these back
Attached File  PXL_20240729_154422431.jpeg   63.75K   0 downloads
Attached File  PXL_20240729_154429066.jpeg   56.16K   0 downloads
Attached File  PXL_20240729_154435490.jpeg   69.06K   0 downloads
Attached File  PXL_20240729_154441769.jpeg   56.5K   0 downloads
Attached File  PXL_20240729_154448293.jpeg   64.22K   0 downloads
Attached File  PXL_20240729_154453383.jpeg   52.59K   0 downloads
Attached File  PXL_20240729_154508983.jpeg   42.78K   0 downloads
Attached File  PXL_20240729_154516692.jpeg   39.28K   0 downloads
Yesterday I spent welding on the upper engine arm steady bracket to the bulk head cross member and opened up the holes for the upper shock absorber mounts ready to weld on the  captive nuts for the bottom of the mounts.
Attached File  PXL_20240824_172940509.jpeg   54.11K   0 downloads
Attached File  PXL_20240824_172958741.jpeg   49.94K   0 downloads
Attached File  PXL_20240824_173011621.jpeg   47.78K   0 downloads
I run a few welds across the top to help stop it from pulling away.
Attached File  PXL_20240824_172837118.jpeg   65.95K   0 downloads
Attached File  PXL_20240824_172845545.jpeg   76.92K   0 downloads
Attached File  PXL_20240824_172928805.jpeg   63.74K   0 downloads
Edited by Mito, 25 August 2024 - 09:35 AM.
