1989 Mayfair Project
44 replies to this topic
#16 Mito
Mito
  • 408 posts
Posted 01 March 2016 - 06:10 PM
I managed to get most of the inner sill repair panel welded in over the weekend. Just like the other side, it didn't quite meet up with the original were the front foot well is.
Attached File  WP_20160228_14_26_31_Pro.jpg   50.01K   22 downloads
Inner Sill Stiffner welded up.
Attached File  WP_20160228_14_26_00_Pro.jpg   36.63K   20 downloads
Some of the weld between the new sill and the original floor.
Attached File  WP_20160228_14_26_10_Pro.jpg   44K   20 downloads
Penetration of the weld above. It looks ok to me.
Attached File  WP_20160228_14_26_22_Pro.jpg   50.69K   21 downloads
I just have to finish welding up the front and the rear bins. Hopefully I'll get chance to do it next weekend.
Attached File  WP_20160228_14_25_53_Pro.jpg   61.12K   19 downloads
#17 lawrence
lawrence
  • 1,330 posts
Posted 02 March 2016 - 11:56 PM
All looking great there :) maybe try a higher welder power and possibly a slower wire speed for flatter welds mate. Yours still will be strong but trying that may make knocking the tops off the weld With a flap disk a bit swifter
Keep it up!
Lawrence
#18 Mito
Mito
  • 408 posts
Posted 05 March 2016 - 05:56 PM
Thanks. I will give that a go.
#19 Mito
Mito
  • 408 posts
Posted 06 March 2016 - 06:01 PM
Cranking up the amps seems to have done the trick.
Attached File  WP_20160306_16_18_16_Pro.jpg   49.4K   20 downloads
Attached File  WP_20160306_16_18_26_Pro.jpg   56.37K   16 downloads
It's all ground back and primed now but didn't take a picture.
There's just the front flitch to sort out before its ready for the outer sill.
The only question is do I replace the doorstep before the outer sill is put on or after? I was thinking it would be best to use the current doorstep to line up the outer sill before I cut it off.
Edited by Mito, 06 March 2016 - 06:04 PM.
#20 Mito
Mito
  • 408 posts
Posted 13 March 2016 - 07:22 PM
I got quite a few things done today.
Jacking point mounted on n/S
Attached File  WP_20160313_17_10_29_Pro.jpg   56.3K   5 downloads
Rust in the nearside rear quarter cut out
Attached File  WP_20160313_16_23_33_Pro.jpg   68.01K   9 downloads
Nearside outer sill offered up and the doorstep cut out.
Attached File  WP_20160313_16_23_25_Pro.jpg   63.27K   3 downloads
Offside jacking point fitted and doorstep cut out.
Attached File  WP_20160313_13_49_35_Pro.jpg   62.87K   4 downloads
Offside flitch finished off
Attached File  WP_20160313_13_24_30_Pro.jpg   42.1K   4 downloads
#21 Mito
Mito
  • 408 posts
Posted 25 March 2016 - 09:45 PM
Today was spent fitting the passenger side door step.
#22 James_eaton_thewholething
  • 1,063 posts
Posted 25 March 2016 - 10:58 PM
Looking good my friend keep up with all the hard work and it will be done in no time
#23 Mito
Mito
  • 408 posts
Posted 30 March 2016 - 05:36 PM
Thanks. I'm hoping it will be ready for next years l2b although I was saying that last year 😕
Edited by Mito, 30 March 2016 - 05:47 PM.
#24 Mito
Mito
  • 408 posts
Posted 30 March 2016 - 05:39 PM
It now has an offside outer sill.
#25 Mito
Mito
  • 408 posts
Posted 17 July 2016 - 08:54 PM
I've not updated this in a while but have been making steady progress.
Nearside outer sill fitted
Attached File  WP_20160330_16_00_42_Pro 1.jpg   51.9K   2 downloads
Patching a hole in the floor.
Attached File  WP_20160522_16_40_50_Pro.jpg   73.12K   5 downloads
The other side with some primer
Attached File  WP_20160522_17_32_56_Pro.jpg   60.28K   3 downloads
The boot all primed and she's now ready to be dropped down off of the spit.
Attached File  WP_20160530_19_07_24_Pro.jpg   60.62K   7 downloads
Now to work on the shock absorber mounts. It doesn't look good from the outside...
Attached File  WP_20160522_13_53_23_Pro.jpg   67.72K   2 downloads
And behind the bracket...
Attached File  WP_20160522_13_53_33_Pro.jpg   76.58K   5 downloads
It was like this on both sides is they were both trimmed back and cleaned up...
Attached File  WP_20160522_13_53_45_Pro.jpg   54.57K   3 downloads
Attached File  WP_20160605_15_37_06_Pro.jpg   66.3K   4 downloads
After doing this side first I realised it was going to be difficult to cut the inner wing repair panel to fit, so the n/s was cut squarely around the bulge.
Repaired...
Attached File  WP_20160705_17_25_41_Pro.jpg   68.11K   4 downloads
After this I tacked on the inner wings and clamped the front-end on roughly. Looks like I have some work to do as nothing lines up.
Scuttle to front wing gap...
Attached File  WP_20160710_14_54_12_Pro.jpg   26.07K   7 downloads
Front panel to wing gap...
Attached File  WP_20160710_14_53_33_Pro.jpg   70.59K   6 downloads
Attached File  WP_20160710_14_54_01_Pro.jpg   60.4K   5 downloads
I'm a bit unsure as to how to line these up at the minute, so I've abandoned for the time being and have begun work on skinning the doors. I removed the original skins a while ago so they just needs sorting out and the new skins putting on. So far I've got the frames sorted out ready for the skins to be put on.
I started with this...
Attached File  WP_20160717_13_02_28_Pro.jpg   90.24K   5 downloads
And after a few hours of cutting, welding and grinding , I now have this...
Attached File  WP_20160717_17_34_46_Pro.jpg   83.95K   9 downloads
The view from the other side...
Attached File  WP_20160717_17_35_15_Pro.jpg   55.94K   9 downloads
That's all for now. The other door is in primer and this oen just needs some rust treatment and paint before the skin is applied.
#26 James_eaton_thewholething
  • 1,063 posts
Posted 18 July 2016 - 05:37 PM
Use a bit of brute force to sort the gaps with the front panels out. Are the heritage or pattern parts ?
#27 Mito
Mito
  • 408 posts
Posted 18 July 2016 - 06:02 PM
heritage wings and pattern front panel.
I think my plan is to sort the doors out and then use the doors to line up the a-panels which I hope gives me a good panel to then line up the wings. I've already bolted the front panel to the sub frame so not much movement on that.
It looks like there is no way that they can line up at the moment but I'm hoping that it will just take some brute force
#28 James_eaton_thewholething
  • 1,063 posts
Posted 18 July 2016 - 08:12 PM
I have done exactly the same with the same panels literally had to fire the wings into place and the get the front panel to line up as best as possible
#29 Mito
Mito
  • 408 posts
Posted 06 August 2016 - 03:51 PM
Painted the inside of both doors. Hopefully it will last a while longer.
Attached File  WP_20160806_14_31_12_Pro.jpg   70K   1 downloads
Plug welded the two bottom corners and ground back. There's also seam welds down the two sides at the top but didn't take a picture.
Attached File  WP_20160806_16_42_28_Pro.jpg   36.26K   6 downloads
First door on the car. I think the gaps look pretty good.
Attached File  WP_20160806_16_42_02_Pro.jpg   55.57K   5 downloadsAttached File  WP_20160806_16_42_33_Pro.jpg   50.33K   4 downloadsAttached File  WP_20160806_16_41_56_Pro.jpg   50.18K   5 downloads
The only bit that looks a bit off is the gap at the front of the door seems to be a bit tight but I need to look at it again with the a panel on.
Attached File  WP_20160806_16_42_10_Pro.jpg   38.88K   5 downloads
Edited by Mito, 06 August 2016 - 04:55 PM.
#30 Mito
Mito
  • 408 posts
Posted 21 August 2022 - 12:28 PM
It's been a while since the last update on this one, but 6 years later it's about to be moved into the garage ready for work to begin again.Attached File  PXL_20220821_122433448.jpg   106.1K   0 downloads
