Hi,
Please bear with me as I know nothing about cars and am new to the Mini scene
I recently took my car to a garage (non specialist) as the clutch has seized up, and there was brown slush in the radiator. The garage fitted a new slave cylinder and filled up the clutch fluid which solved that problem. They then went to flush the radiator out and subsequently blew the heater hose connector as they didn't wait for the engine to cool before taking the cap from the radiator.
The next day, the car started cutting out completely so I took it to a Mini specialist who fitted a new Heater control valve, this solved that problem for about a week.
The car then started to Idle at about 100 before cutting out after about 5-10 seconds. I took the car back to the specialist who found a leak to the manifold, they fixed that and reset the codes on the ECU.
It worked for a day and then Idled at about 100 and cut out again, this time the car overheated with smoke coming from the engine, when I took it back to them they fitted a new hose from the inlet manifold to the thermostat housing, this fixed both Idling and overheating problem until the next day when the idling started again.
I decided to take it to a different Mini specialist as I thought a different brain could solve the problem. They checked all vac pipes at the back of the manifold and re set the lost motion gap, they also cleared the map sensor of oil, again this worked until I started the car for the second time at home.
Idling is now a problem again and there is tons of black smoke coming from the exhaust when I accelerate!
I know its lengthy but thought I would give you the cars history since I have went it (2 months)
Any help would be much appreciated as I am not mechanical minded!!!
