Not all Minis leak oil
Lying is a sin. You will end up in hell, driving a 3 cylinder Citroen C2 as your punishment.
Posted 08 July 2015 - 07:18 PM
Posted 08 July 2015 - 07:36 PM
I also had a Triumph 650 they all leak oil according to myth, mine didnt, its all in the detail and not wacking it together
Posted 09 July 2015 - 11:06 AM
Far too expensive. You really should do some basic investigation and remedial work yourself. At least do the rocker cover gasket, it costs a pound or so from minispares and is a scoosh to replace. Clean up the underside where there is oil using the spray bottle of gunk and some rags, then see where it is coming from. That really is the only way to know for sure. If there is a drip of oil on the wiggle pin in the bell housing then probably that leak is the primary oil seal and not a gasket. It may not need anything doing though, most minis have a drip there and unless it is a large leak then it is best left alone unless the clutch is slipping.
A little investigation and time could save you hundreds. It may all be stuff you can do yourself. But deffo at least do the rocker cover gasket!
Posted 12 July 2015 - 09:44 AM
Brake cleaner in a spray can is awesome for removing oil on engines.
Posted 12 July 2015 - 09:46 AM
Saying that, mine has not had a wee on the garage floor in a while.
