Oil Leak...opinions?
19 replies to this topic
#1 Lil G
Lil G
    Starting My Mini Up
  • 3 posts
  • Local Club: SMOC
Posted 07 July 2015 - 03:56 PM
Hi guys, fairly new to the mini scene and the forum, so apologies if this is in the wrong place!
I have owned my 1995 SPi for around 2 months now, and have been noticing small amounts of oil on the ground whenever it has been parked. At first I put this down to "Minis leak when they came out of the factory!" but after the spots of oil got larger I decided it needed to be checked out, and took it to a garage that my family have been using for a while, and who we trust fully.
I have just had a quote from said garage of £600-£700, due to the amount of labor needed to reach the 3 separate leaks. The garage have been very open and honest, and have suggested I should possibly give Wynn's oil leak treatment a go, as with a mini the £600-£700 may not fix the leak permanently, and even if it does, there will always be another one!
So, to cut a long story short, what would people suggest I do; pay up for the work, or give the ol' Wynn's a go?
Thanks in advance.
#2 Alex_B
Alex_B
  • 4,573 posts
Posted 07 July 2015 - 04:04 PM
Where are the leaks coming from?
At a guess I would be guessing the gear selector seal, the timing cover gasket. But using any oil treatment to stop leaks is a bad idea! The way they work I think is to swell the rubber seals and gaskets to remove the gap and seal them up, but at best they are a bodge and really not suitable for the mini since the gearbox shares the engine oil and you will likely cause more damage than solve any leaks.
Can you not do this yourself as its not a particularly hard job just labour intensive?
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 07 July 2015 - 04:21 PM
Gear Change, Diff Seals, we need to  know where they said it was to give a opinion on the costs
#4 racingbob
racingbob
  • 3,061 posts
Posted 07 July 2015 - 05:03 PM
I had a leak from the drivers outer dif housing flange
I put some extralube ZX1 in the oil (not for the oil leak)
for more engine protection and my leak has stopped
it has good reviews, you may want to try that
also make sure you have 20 50 oil in there
I use Valvoline VR1 20 50 its been the best I have found
but be good to know where there coming from
#5 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 07 July 2015 - 05:10 PM
As stated, we'd need to know where the leaks are coming from. I had leaks from both the selector and driver's side gearbox seal. £8 of parts and an afternoon = no more leaks!
#6 brivinci
brivinci
  • 1,173 posts
Posted 07 July 2015 - 05:17 PM
I know everyone jokes about our cars "marking their territory" typically but I can tell you that my car has zero leaks. It is totally possible and there is really no magic to it. I use only gen (the $$$) seals and gaskets. In 3 rebuilds (not the gaskets fault. haha) I have had not a single leak.
#7 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 07 July 2015 - 05:42 PM
I have had mine in the garage and the last 4 yrs not a drip
#8 FlyingScot
FlyingScot
  • 2,664 posts
Posted 07 July 2015 - 08:40 PM
Attached File  image.jpg   32.99K   2 downloads
Give us a clue.........
FS
#9 Blatherskite
Blatherskite
  • 501 posts
  • Local Club: Norsk Mini Cooper Club
Posted 08 July 2015 - 08:45 AM
My old Traveller only stopped leaking when the sump was empty :-(
#10 Lil G
Lil G
    Starting My Mini Up
  • 3 posts
  • Local Club: SMOC
Posted 08 July 2015 - 02:33 PM
Thanks all for the speedy replies.
I have been on the phone to the garage and the three leaks are:
1. Sill behind the crank pulley - new gasket and maybe pulley
2. Small leak from the rocker cover - new gasket
3. Inside the bell housing
They said the bell housing is most likely to be a gasket, but won't  know until taken apart - hence the v.high labor costs.
Hope this update gives you a better idea of the problems.
#11 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 08 July 2015 - 04:42 PM
Thats way to much labour unless they charge £100 a hour
Clutch housing leak if its coming out the Jiggle Pin is the Primary oil seal
#12 666junky
666junky
  • 1,225 posts
Posted 08 July 2015 - 04:46 PM
A whole replacement engine is cheaper than their quote.. i understand they have to charge labour but really? That much? I can understand if its a full rebuild of the engine / strip down etc but that seems a bit ott.
If you go down replacement route then make sure you dont buy a plum, swapping it is real easy and should take a day maximum with two people
#13 Richie83
Richie83
  • 1,495 posts
Posted 08 July 2015 - 06:42 PM
For starters I'd have a go at fixing the rocker cover leak yourself. You'd be surprised how much a small leak from here can drip. It'll cost you a few quid and a careful couple of hours to get it right.
#14 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 08 July 2015 - 06:45 PM
Say that with a straight face. :shifty:  :bah:
#15 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 08 July 2015 - 07:05 PM
Not all Minis leak oil ;D
