Sump Plug 5/8" Unc Thread Repair Kit
18 replies to this topic
#16 mini-auto
mini-auto
  • Just Joined
  • 102 posts
Posted 20 September 2015 - 08:12 PM
Hey Spider, Do you fit a copper washer under the head of the M20 ?
Should I flood the M20 threads with thread lock (Loctite) when I install & rely on that to give a good seal ?
What do you recommend ?
#17 Spider
  • 14,841 posts
Posted 20 September 2015 - 08:40 PM
Yes on both counts, only I don't flood the threads with loctite, just enough to get the job done. I also clean both threads before applying the loctite with thinners. Also, be sure that the copper washer is annealed, so many out of the box these days are hard.
#18 pothole
pothole
  • 317 posts
Posted 21 September 2015 - 07:51 AM
There is nothing wrong with helicoils just the expense of buying the set, for what will be a one off job.
What I did to repair mine as I don't have access to engineering machines anymore, was as Spider did tap out the thread to 20mm, but just use the 20mm bolt and a copper washer, I removed the magnet from the old sump plug and pressed it into the 20mm bolt. But don't use a high tensile M20 they are a pig to drill, and use plenty of cutting compound on the tap to try and stop the swarf entering the sump.
#19 NateDogg2909
NateDogg2909
  • 188 posts
  • Local Club: NottsAboutMinis
Posted 18 March 2018 - 11:03 AM
Now that is an idea and a half, why try and make a sleave with the lathe when you are already half way there with a m20 bolt.
All I need to do now is find out if my friend has a 18.5mm drill bit and m20 tap, otherwise I might as well buy the both myself and a m20 magnetic sump plug.
Thanks for the brilliant idea
