Reuse Crankshaft Oil Seal
7 replies to this topic
#1 Minigirl
Minigirl
    With Steve
  • 1,109 posts
Posted 03 July 2015 - 02:14 PM
I fitted my brand new reinforced crankshaft oil seal but now need to remove the flywheel housing again. Can I reuse that crankshaft oil seal? It has had no use at all, I only pushed it on the other day with a quality diy fitting tool :(
If I cover the teeth well on the gear and slip it off complete with the housing casing instead of damaging it with a screwdriver getting it out will it be ok?
thanks
#2 klivins
klivins
  • 317 posts
  • Local Club: minimania.lv
Posted 03 July 2015 - 03:04 PM
Should be OK, at least mine is after same procedure 3 years ago. Done 10000 km since.
Edited by klivins, 03 July 2015 - 03:05 PM.
#3 sledgehammer
sledgehammer
  • 3,098 posts
Posted 03 July 2015 - 03:44 PM
Hi
As long as there is no damage to it , it should be fine
remember to put a dab of oil on the seal before refitting the housing , they can quickly wear the lip if dry
#4 Spider
  • 14,838 posts
Posted 03 July 2015 - 07:47 PM
Yeap, should be fine as the other guys have said, just take appropriate precautions when removing it and of course, re-fitting.
Hi
Just to clarify what hammerman has said, only a lick of oil to the lip, not to the mounting diameter.
#5 Minigirl
Minigirl
    With Steve
  • 1,109 posts
Posted 11 July 2015 - 07:48 AM
Thanks I ended up ordering a new one as they was slight damage removing it.
Oh no Why no oil to the mounting diameter?
#6 Spider
  • 14,838 posts
Posted 11 July 2015 - 07:55 AM
Any Oil here may make it slip out.
#7 sledgehammer
sledgehammer
  • 3,098 posts
Posted 11 July 2015 - 01:31 PM
as above , only oil on the seal lip
I have in the past used fairy liquid / tyre soap . to mount oil seals when tight - don't know if it's good practice , but seals can be a bit tight sometimes
#8 Minigirl
Minigirl
    With Steve
  • 1,109 posts
Posted 12 July 2015 - 10:41 AM
Aaaa engines back in now. Will take the risk. It still required some force on the tool to get it in and surely the plastic protector would help stop it falling fully out?
