Fitting Fixed Rear Quarter Glass
3 replies to this topic
#1 darkcat
darkcat
  • 398 posts
Posted 03 July 2015 - 10:56 AM
Morning all
OK, so ive just tried to fit a rear quarter window, with the rubber attached to the body, like with the windscreen/rear window - seems almost impossible.
Should i start with the rubber attached to the glass??
#2 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 03 July 2015 - 11:13 AM
if you put the rubber on the glass and put some cord in the part that fits in the frame overlapping the ends of the cord at the bottom, you can pop the bottom of the rubber onto the lip and have someone push on the glass while you carefully pull the cord from inside the car. If done right, the cord will pull the rubber over the lip.
Ben
#3 corrado vr6
corrado vr6
  • 678 posts
Posted 03 July 2015 - 01:01 PM
When pulling the cord do a circular motion with your arm/hand so it helps lift the rubber up and over the lip, take it slow and it'll be fine
#4 darkcat
darkcat
  • 398 posts
Posted 03 July 2015 - 07:15 PM
Thanks!
Thought i was doing it slightly face about arse...
