Posted 24 June 2015 - 10:24 PM
Posted 24 June 2015 - 11:27 PM
Do you have the time and enough funds to prepare the bodywork? (fix all rust, dents, then put primer coats down and make sure they're sanded flat and smooth, remove trim and fittings?)
If you can do this successfully (and it's mostly a matter of time and concentration/determination) then you have cut the cost of a high quality professional respray by up to 75%. You may even get a better finish than a professional respray, since at lower levels of price they do less bodywork and may or may not make sure all flat surfaces are level (no waves or ripples in the finish, and don't remove the trim [they just use masking tape].)
If the car is already sound (no bodywork needed, existing finish is level) then all you need to do is carefully sand every part of the car that will receive paint for high quality adhesion and remove as much trim and fittings as you are willing to.
I personally would not use a cheap paint because if it deteriorates quickly (as it most likely will if exposed to the elements regularly) you'll be worse off than no paint at all. At least with old paint you can claim to have a "rat rod" look. :)
If you have bare metal already that needs protecting, but you have to expose the car to the elements soon, you can use a good epoxy primer to protect the metal indefinitely, and drive around with the primer-rod look.
Edited by bluedragon, 24 June 2015 - 11:28 PM.
Posted 24 June 2015 - 11:34 PM
Posted 25 June 2015 - 06:39 AM
There have been people on here who have got a very good finish using a roller.
Posted 25 June 2015 - 08:21 AM
It's roughly £40 enough to spray a mini if you do all the prep work your self pretty cheep way of doing it.
If that's what he means. It's just a 2k paint with the laquer already in it so no need to add after wards.
Posted 25 June 2015 - 11:43 AM
I am thinking about doing a car using enamel paint.
Think that's what Land Rover use.
I've used it a lot under the car and arches, so might try an old panel (prepped properly) first.
Edited by lawrie124, 25 June 2015 - 11:43 AM.
Posted 25 June 2015 - 11:52 AM
Edited by Classiclove, 25 June 2015 - 11:54 AM.
Posted 25 June 2015 - 12:00 PM
Would you car to share the outcome?
of course. it's about £50 for 5 litres. Underneath my van still looks like new, and it's a (mostly) daily driver, but keen to try it on an old bonnet or boot.
Also tagged with one or more of these keywords: paint
paint
Mini Technical Sections →
Bodywork, Paint and Detailing →
Identify The Oiginal Body Color CodesStarted by Vítor Brasil , 18 Feb 2025 ![]() |
Does Anyone Know The Colour And Colour Code Of This Mini?Started by Ryanrjstorey , 18 Feb 2025 ![]() |
paint
2K Or Not 2KStarted by BobbyMax , 28 Apr 2024 ![]() |
Looking For Original Paint Codes/colour SuggestionsStarted by BernardMini , 10 Sep 2023 ![]() |
Smoke Grey PaintStarted by aiden_hollis97 , 20 Mar 2023 ![]() |
