Strong Smell Of Petrol
18 replies to this topic
#16 Gerbil367
Gerbil367
  • 646 posts
  • Local Club: GMOC
Posted 26 June 2015 - 09:22 AM
Maccers, I dont get any petrol smell at all now in boot after fitting new breather hose - not sure if MPI even has that?  Is the seal around the filler cap OK?
Did Jason find his problem?
#17 lewBlew
lewBlew
    Previously known as theboybradley.
  • 1,238 posts
Posted 26 June 2015 - 01:02 PM
Yes check the seal on the petrol cap as when I walk past mine I regularly smell a bit (don't they vent?). Again this isn't the strong 'fresh' petrol smell. The one you can't get off your shoes.
Replace the breather hose in the boot, maybe the fuel one too. They aren't expensive  :proud:  Or perhaps the tank is porous somewhere like near the filler?
#18 Dusky
Dusky
  • 5,322 posts
Posted 26 June 2015 - 02:51 PM
I heard all this petrol on hot engines/exhausts is nonsense and that petrol can only ignite with a spark, not just heat. Don't quote me on it though  >_<
It isn't really nonsense, it does indeed need a spark, but the problem is that a little touch of static electricity is more than enough :P
#19 Brian422
Brian422
  • 38 posts
Posted 26 June 2015 - 03:20 PM
I got caught without any tools on a Sunday when I noticed a strong smell of petrol coming from under the bonnet. Had a look only to find petrol dripping onto exhaust manifold. To cut a long story short, I'd recently replaced old fuel pipes with new braided from Burdens. AA man found inner rubber hose cracking and disintegrating. Unfortunately, could not see leak because of braiding. Suggested I replaced all fuel lines with correct type for unleaded fuel ... I didn't even know there was a difference. He also suggested forgetting braided as it's not possible to determine condition of rubber, or whatever they use these days.
