Mini Cooper Convertible Roof Problem
2 replies to this topic
#1 paul24dual
paul24dual
    Starting My Mini Up
  • 2 posts
Posted 18 June 2015 - 01:40 PM
Hi all,
I have a Mini Cooper 2004 convertible and have a problem with the roof.
When we try to fold the roof the passenger side does not come out of its hole. After inspecting the usual things like the parcel shelf etc, i can't see any faults
However when you push the arm up out of the hole the roof folds back perfectly. After further inpection there is a pin with a rubber cover and thread that screws inside the end of the arm which was loose, we have tried to screw this part back into the arm but will not screw all the way up and comes loose again after operation.
Could this be the cause of the problem and how would i fix this...?
paul
#2 Lincsminbin
Lincsminbin
  • 78 posts
Posted 18 June 2015 - 01:51 PM
Hi paul24dual,
This forum is more focused on the 'classic' mini (pre BMW).  Someone may have an answer, but you are probably better off asking the question on the Mini2 forum at the link below.
http://www.mini2.com/forum/
#3 paul24dual
paul24dual
    Starting My Mini Up
  • 2 posts
Posted 18 June 2015 - 01:58 PM
Thanks very much!!
