Yamaha R6 5Eb Charging System
Posted 14 June 2015 - 07:27 PM
Put it on the trickle charger for a while, put my MM on amps and tested for leaks (disconnected negative and put it in between) and shows 0 reading....
Battery shows 11.6v, drops to about 8 while starting and charges at 13, nothing in use, drops to about 12.3 when lights turned on....
What's next?
Posted 14 June 2015 - 08:52 PM
A "good" battery will show 12.7v on a M/M , a "dead" battery will show 11.7v or less. You have a "dead" battery.
Posted 14 June 2015 - 09:08 PM
check reg rec then alternator/stator.
Posted 15 June 2015 - 06:07 AM
Posted 15 June 2015 - 10:22 AM
Posted 16 June 2015 - 09:46 PM
Yamahas are good at dropping one phase on the stator, the voltage output from the rectifier then tends to look normal (depending on the reaction time of the meter you are using) but there isn't actually enough output to charge anything properly. I'm currently fighting with a Rhino at work daily which needs a new stator and all I do is strap a massive bettery into it that I charge now and then. There are loads of videos on the web showing you how to test the individual phases on the stator. It probably needs a new one, and a new battery.
