Torque Setting For Flywheel Bolt Needed
4 replies to this topic
#1 gazza01
gazza01
  • 644 posts
Posted 12 June 2015 - 11:54 PM
Hi there.
I am about to mate the gearbox casing to the crankcase and will need some definate torque settings as I am seeing different settings depending what site or post I search.
The engine is a 1330 a+
The flywheel bolt, I have seen settings from 112 to 150 lbs ft
I was thinking more on the 150 side of things?
the bolts for the flywheel casing 18?
Any others appreciated.
Thanks.
#2 zerobelow
zerobelow
  • 136 posts
Posted 13 June 2015 - 12:54 AM
Have you checked the pinned topic:
http://www.theminifo...gs-reformatted/
I'm pretty sure that with 37,000 views, if it had any major errors, they would have been corrected by now.
#3 Spider
  • 14,843 posts
Posted 13 June 2015 - 12:55 AM
OK - Factory Info says 115 ft / lbs.
I never use less than 150 ft / lbs, I also use a light machine oil on the taper.
#4 gazza01
gazza01
  • 644 posts
Posted 13 June 2015 - 11:05 AM
Yeah I watched a Bill Sollis build dvd recently and that was 150 with a dab of copper grease on the bolt
#5 A-Cell
A-Cell
  • 1,610 posts
Posted 13 June 2015 - 12:34 PM
That is bad practice, greasing a thread increases the tensile load on the fixing for a given torque.
Standard torque, dry thread, is best practice. There really is no need to over torque.
If you want belt and braces then a smear of loctite would be better.
