Painting Steel Brake Pipes
10 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 12 June 2015 - 08:48 AM
Hi;
I am replacing all of the brake pipes on the Rear Subframe but the length that runs from the rear to the front of the Mini seems ok, was just covering in underseal etc.
I have cleaned it off and the pipes look OK, can I paint them?
I was going to smoke some U-POP Etch Grey Primer and then Red Enamel or just straight on with Blue Smooth Hammerite. Just some paint that I have spare?
#2 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 12 June 2015 - 02:59 PM
Some MOT Testers do not like paint or underseal covered brakepipes as they cant see the condition of the pipes beneath.
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 12 June 2015 - 06:10 PM
Its a Hour + to fit a new Kunifer pipe and its fit and forget, why not bite the bullet and fit the front/rear?
Edited by KernowCooper, 12 June 2015 - 06:10 PM.
#4 adam_93rio
adam_93rio
  • 3,271 posts
Posted 12 June 2015 - 09:34 PM
Why would you want to paint brake pipes
#5 peter-b
peter-b
  • 773 posts
  • Local Club: still looking
Posted 12 June 2015 - 10:05 PM
Probably for corrosion protection but to me its a two way street, you don't paint them they rust, you do paint them and then you can't see the rust (hole). Assuming they're steel tubing. IMO, I'd leave them with just a spray of tectyle or similar, or get copper* ones.
* copper lines aren't actually allowed over here.
#6 Cooperman
  • 23,278 posts
Posted 12 June 2015 - 10:53 PM
Get kunifer ones - problem solved.
#7 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 13 June 2015 - 04:10 PM
I bet I could fit a new Kunifer pipe in the time it takes to clean and paint all the metal surface of the front to rear, fit a new Kunifer pipe and forget it,
#8 rally515
rally515
  • 3,848 posts
Posted 13 June 2015 - 04:25 PM
Somewhat related topic I thought I'd take the opportunity to ask everyone about, does anyone know were I can get Stainless steel hardline coils from in the Uk ? every search has failed so far and it's seeming impossible to find any, only braided hose appearing Grrr
#9 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 14 June 2015 - 07:35 AM
Is Kunifer the same as Cupronickel?
#10 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 14 June 2015 - 07:54 AM
Basically but they have different ratios of metals in them. There are a few different grades of each.
I seem to remember Demon Tweeks stocking stainless hard line systems, stainless is a bit brittle for brake lines though surely?
#11 Carlos W
Carlos W
  • 10,114 posts
Posted 14 June 2015 - 08:44 AM
To clean and paint them properly you're going to have to partially remove them.
Just remove them and fit Kunifer
