This is going to be awesome
Mk2 Midas ( Gone Full Circle)
#16
Posted 09 November 2015 - 09:51 PM
#18
Posted 11 November 2015 - 11:45 PM
#19
Posted 12 November 2015 - 02:07 PM
It's a GT17, apparently they are good on the 1275 A series and the Micra engine is the same bore & stroke so it should work well.
#20
Posted 14 December 2015 - 08:54 AM
I seem to remember these being advertised with coilover spaxes on the back when new ...These were real quality kits, much better made than the mini marcos's they were sort of based on.
It will fly with the Micra lump in it.
#21
Posted 14 December 2015 - 05:33 PM
I'm not going crazy with the engine but I guess 140-150bhp will be the final result, which should be plenty fast enough
#23
Posted 20 December 2015 - 09:20 PM
Pretty much finished the electonic speedo code. Just need to get it mounted in the clocks. Although I'm thinking of changing to oled rather than LCD screens
Managed to get an hour out the garage today so I stripped down the rear radius arms, nothing special to report other than the pins and bushes seem to be new :) one worrying thing was both hub nuts where finger tight ( a strong breeze could have undone them) at first I thought they have just been nipped up to get the wheels on etc to push the car around but both had split pins in :-S
A bit of paint and the arms can go back together, although new wheel cylinders and shoes will be required as this is what I found when I took the drums off
I'll probably take the opportunity to fit some minifins at the same time.
Edited by l_jonez, 20 December 2015 - 09:29 PM.
#24
Posted 01 January 2016 - 05:10 PM
The Midas uses Coilovers so there is no need for the knuckle joint cup and surrounding casting, so off it came.
Then things escalated and I ended up getting the flap disk out
Hopefully mini spares will have a January sale and I can get all the required parts to build it all back up.
#26
Posted 24 January 2016 - 07:43 PM
Hi,
You might want to weld from inside where you have flange nuts.
Log style manifold works quite well so I'm keen to find out what Micra enige can take with std internals.
Atchi
#28
Posted 26 January 2016 - 10:38 PM
Hi,
Atchi
Atchi ... Shouldn't you be looking at G13b threads? Dom
#29
Posted 30 January 2016 - 11:35 PM
I know buy I have help Dave who is making his cars with Micra engines....
I'm still working on my Mini!
#30
Posted 20 May 2016 - 04:06 PM
Work came to a halt on the manifold as I've decided to buy a Tig welder
The floor has been cleaned up and so far one half has been stone chipped, the other half will be done tomorrow...
Also Ive bought a small vw intercooler, which will be located behind an unused air duct
Decided that there wasn't enough surface area so I cut out the duct.
