I've just got my hands on a metro turbo set up.. Turbo, carb, manifolds, fuel reg....
long story short I've come into the possession of a 1293cc NA engine in which has got one nasty melted piston... thats the only bad thing about the engine.. I've got receipts to say...
full gearbox rebuild with 4 pinion diff
turbo clutch,
lighten flywheel,
high compression rods
fast rod cam
new crank
new oil pump
skimmed head
double value springs
My thoughts were to get a rebore resulting in a 1275+40 and get new pistons in... and the turbo on add and intercooler
My First question is with new pistons will this set up cope or will i just end up with more melted pistons?
Secondly I've been doing my homework on turboing, and I'm finding it hard to familiarise myself with the ignition system... from what i can work out when the turbo is running the timing will be no good using a standard dizzy... and result in the engine going bang... i could really do with someone spelling this part out to me as I'm at bit of a loose end
all help appreciated
thanks in advance
